Threads: 39
I'm trying to make visualization page with camera, but I can't seem to find out what form of URL to use. Could you help me? I think it should be rtsp onvif.
IP: 192.168.1.110
username, password
Also, are there any other parameters?
Threads: 21
mjpeg
Threads: 21
It depend of the camera manufacture, there is no universal solution
![Sad Sad](https://forum.logicmachine.net/images/smilies/sad.png)
First try to open video in browser.
Threads: 39
So it looks like I have found the right syntax for my camera, it is
rtsp://username:password@IPADDRESS:554/cam/realmonitor?channel=1&subtype=0
Unfortunately I still can't make it work through visualization, only through VLC. Is there a way to make browser play RTSP stream inside of it, not through some 3rd party player like VXG or VLC player?
Threads: 21
(17.07.2018, 07:57)Jayce Wrote: So it looks like I have found the right syntax for my camera, it is
Clean browser can play only mjpeg, other formats need a plugin.
Threads: 39
So is there a way to play the camera stream inside visualization of either chrome or safari browser?
Threads: 21
(17.07.2018, 08:25)Jayce Wrote: So is there a way to play the camera stream inside visualization of either chrome or safari browser?
To be honest you can only do it when camera support mjpeg. Not every browser support or allow plugings to be installed. There are some options if your camera support other formats. There are devices which can convert video formats to the one you need. We were playing with android app TinyCam
https://tinycammonitor.com/ installed on a android TV was nicely converting it to mjpeg video. The only issue was not the most stable hardware.
I saw recently some other option with cloud base conversion but had no time to try it out yet. Something like this should also work
https://www.ipcamlive.com/ free for few cameras.
Threads: 161
what kind of camera model do you have?
Done is better than perfect
Threads: 39
I have some kind of Dahua IP camera
Threads: 21
Try something like that. Also check if there is new firmware for your cam.
http://IP/axis-cgi/mjpg/video.cgi
Threads: 161
Threads: 39
Okay I have found in my camera settings option to set encoding to mjpeg which I did. Then I tried the link which I think should have worked but still doesn't. If the encoding is mjpeg do I type in http url or rtsp one?
Threads: 41
It must be mjpeg over http. Browsers do not understand rtsp without plugins.
Threads: 39
Thank you very much, got it working.
Threads: 36
(17.07.2018, 11:38)Jayce Wrote: Thank you very much, got it working.
What is the link for the mjpeg video ?
KNX Advanced Partner + Tutor
Threads: 21
Here is nice webpage which provides lots of urls for different cameras
https://www.ispyconnect.com/sources.aspx
