Mosaic heating widget - Resolution temperatur value
Hi.
I attached a picture. The only Mosaic widget i can find, that have the possibility to adjust my floor heating by 0,5 C, is the Thermostat widget. The Thermostat widget contains a lot of information i don't need. Is there some other way to get a simple Heating widget for adjusting by 0,5C? I have tryed to use Widget Creator, but it seems this don't support 0,5 degrees adjusting.
Kai-Roger
In the thermostat widget if you don't link the objects corresponding to icons you don't need then they will not be visible.
In did 0.5 change would be useful will add it to the list for the future.
(10.08.2018, 09:39)Daniel. Wrote: Hi
My bad. I did not see that the other functions would be hidden. Thanks.
Sent fra min SM-G930F via Tapatalk
Kai-Roger
Hi Daniel
Do you plan on adding 0,5 posibilities on the widget builder altso? Would be nice to build a special custom thermostat myself.
Kai-Roger
One day Smile
Kai-Roger
