Visualization Icons Position Rotate
Hello All,
Is there any way to rotate the icons on the visualization by degrees? Or better is there a way to add a third attribute to all icons (except from the element position and size) like "rotation"?
I am having some floor plans where I need to add some Link Objects but the sourface is not always a 90° square.
Regards,
This can be done via Custom CSS. Set Additional classes to rotate-30 of your element. Change degree as needed.
Add to custom CSS:
.rotate-30 {   transform: rotate(30deg); }
(25.09.2018, 07:03)admin Wrote: This can be done via Custom CSS. Set Additional classes to rotate-30 of your element. Change degree as needed.
Add to custom CSS:
Hello Admin,
Thank you for your reply. I have tried the code but didn't see any difference on the rotaion of the element. Instead it is as usual positioned. Please see below if i did correctly what you suggested.
Regards
Delete the 1, 2, 3 numbers. this is not part of the code.
(25.09.2018, 07:46)Daniel. Wrote: Delete the 1, 2, 3 numbers. this is not part of the code.
Hello Daniel.,
I did it and its the same result. Any other idea?
Regards
It works for me
You will see it only in Visualization, not it the editor
(25.09.2018, 09:03)Daniel. Wrote: It works for me
Yes now I see. It would be better to be visible while using the editor for a correct positioning of the element. But I got it now.
Thank you very much    Smile
Add to custom CSS:
Is there a way to have the icon roatate according to a value? What I would like is for the icon to simulate a fan running, and that the icon rotates as the fan is running, and standing still when the fan stops.
You can SVG icon with animation:
https://forum.logicmachine.net/showthrea...132#pid132
Or use this icon for active
https://forum.logicmachine.net/showthrea...49#pid9349
(27.09.2018, 10:21)admin Wrote: You can SVG icon with animation:
Great.
Thanx.
Dear Daniel,
I would like to do the same customisation as you did.  Based on your screenshots I suppose that you rotated an object (value and icon) by 30 degree.
This is what did not work for me. If I test the same with an image, than it rotates.
Do you have any idea why it is not working?
Yes, object with additional class rotate-30 and the code above in custom CSS. I just tried it once more to be sure nothing has changed in latest fw. Test in final visu not editor.
(20.01.2021, 15:47)Daniel. Wrote: Yes, object with additional class rotate-30 and the code above in custom CSS. I just tried it once more to be sure nothing has changed in latest fw. Test in final visu not editor.
I have tested it in final visualisation. As I mentioned it works with an image, but with an object it does not do the same.
Logicmachine version: 20180822
Do you use standard icon or something custom?
(20.01.2021, 16:34)Daniel. Wrote: Do you use standard icon or something custom?
Actualy with no icon just value. I tested it together with factory and custom icons also but with no success.
That works too, maybe it is browser cache
Try adding !important to the CSS rule:
.rotate-30 {   transform: rotate(30deg) !important; }
(21.01.2021, 07:25)admin Wrote: Try adding !important to the CSS rule:
Now it is working. Thanks alot!
Add to custom CSS:
When I create the code in CSS ho use it in object to rotate the icon?
Best regard
