DALI DT8 Dimmer
Hi everyone!
I want to buy this DALI device: http://www.lunatone.com/produkt/dali-2xc...dimmer-cv/
to dimm Tunable White LEDs strips.
it uses the DT8 protocol. Is it possible to run it with the new pre-release firmware of August?
How?
Cheers!
Elkin
We don't have ballasts to test new DALI features, but the latest FW has support for raw telegrams which can be used to send any kind of DALI telegram. There's also an updated DALI package in the works which has new commands supported. We can provide it for you if you are willing to test it.
(08.11.2018, 08:07)admin Wrote: We don't have ballasts to test new DALI features, but the latest FW has support for raw telegrams which can be used to send any kind of DALI telegram. There's also an updated DALI package in the works which has new commands supported. We can provide it for you if you are willing to test it.
OK, will buy the latest ballasts and we can test them together  Big Grin
Hi everyone!
i've made tests with Easydim DALI-MIX-DT8 dimmer and its work
you will need to install new dali package (Admin will provide soon)
to set color temp use following script
require('user.dali')
colortemp = 7000 -- in kelvin
address = 47
mirek = math.floor(1000000 / colortemp)
dtr0 = bit.band(mirek, 0xFF)
dtr1 = bit.band(bit.rshift(mirek, 8), 0xFF)
dalicmd(1, 'setdtr1', { value = dtr1 })
dalicmd(1, 'setdtr0', { value = dtr0 })
dalicmd(1, 'enabledevicetype', { value = 8 })
dalicmd(1, 'setcolortemp', { addrtype = 'short', address = address  })
dalicmd(1, 'activate', { addrtype = 'short', address = address })
to make light warmer use this
dalicmd(1, 'colortempwarmer', { addrtype = 'short', address = 47  })
cooler
dalicmd(1, 'colortempcooler', { addrtype = 'short', address = 47  })
Which DT8 control type did you use? As far I remember there are:
- color temperature in Kelvin
- XY coordinate
- RGBW
I'm guessing it is the color temperature.
(28.11.2018, 10:12)Daniel. Wrote: Hi
- XY coordinate
- RGBW
this dimmer has cold white and warm white output only. so I use only temp color comands
I have another device DALI-ST-DT8 (RGBW dimmer) and I will try other comands with it.
before this I will try to set color limits
Some functions for Type 8 temperature control
function getCurrentTc(gateway, addr)
   code = 2 -- parameter code to get current Tc
   res, err = dalicmd(gateway, 'setdtr0', { addrtype = 'short', address = addr, value = code })
   if err then return nil, 'setdtr0 error: ' .. err end
   res, err = dalicmd(gateway, 'enabledevicetype', { addrtype = 'short', address = addr, value = 8 })
   if err then return nil, 'enabledevicetype error: ' .. err end
   res, err = dalicmd(gateway, 'querycolorvalue', { addrtype = 'short', address = addr })
   if err then return nil, 'querycolorvalue error: ' .. err end
   hb = res:byte()
   res, err = dalicmd(gateway, 'querydtr0', { addrtype = 'short', address = addr })
   if err then return nil, 'querydtr0 error: ' .. err end
   lb = res:byte()
   mirek = bit.lshift(hb, 8) + lb
   tc = 1000000 / mirek
   return tc
function getCoolestTcLimit(gateway, addr)
   code = 128 -- parameter code to get coolest Tc limit
   hb = res:byte()
   lb = res:byte()
   return tc
function getCoolestTcLimitPhys(gateway, addr)
   code = 129 -- parameter code to get coolest Tc physical limit
   hb = res:byte()
   lb = res:byte()
   return tc
function getWarmestTcLimit(gateway, addr)
   code = 130 -- parameter code to get warmest Tc limit
   hb = res:byte()
   lb = res:byte()
   return tc
function getWarmestTcLimitPhys(gateway, addr)
   code = 131 -- parameter code to get warmest Tc physical limit
   hb = res:byte()
   lb = res:byte()
   return tc
function setWarmestTcLimit(gateway, addr, tc)
   code = 1 -- parameter code to set warmest Tc limit
   res, err = dalicmd(gateway, 'setdtr2', { addrtype = 'short', address = addr, value = code })
   if err then return nil, 'setdtr2 error: ' .. err end
   mirek = math.floor(1000000 / tc)
   dtr0 = bit.band(mirek, 0xff)
   dtr1 = bit.rshift(bit.band(mirek, 0xff00), 8)
   res, err = dalicmd(gateway, 'setdtr0', { addrtype = 'short', address = addr, value = dtr0 })
   res, err = dalicmd(gateway, 'setdtr1', { addrtype = 'short', address = addr, value = dtr1 })
   res, err = dalicmd(gateway, 'storecolortemplimit', { addrtype = 'short', address = addr })
   if err then return nil, 'storecolortemplimit error: ' .. err end
   return res, err
function setCoolestTcLimit(gateway, addr, tc)
   code = 0 -- parameter code to set coolest Tc limit
   return res, err
function saveSceneTc(gateway, addr, tc, arc_level, scene)
   -- Save scene with saved Tc and Arc level
   mirek = math.floor(1000000/tc)
   if err then return nil, 'setdtr1 tc error: ' .. err end
   if err then return nil, 'setdtr0 tc error: ' .. err end
   res, err = dalicmd(gateway, 'setcolortemp', { addrtype = 'short', address = addr })
   if err then return nil, 'setcolortemp error: ' .. err end
   res, err = dalicmd(gateway, 'setdtr0', { addrtype = 'short', address = addr, value = arc_level })
   if err then return nil, 'setdtr0 arc_level error: ' .. err end
   res, err = dalicmd(gateway, 'storescene', { addrtype = 'short', address = addr, value = scene })
   if err then return nil, 'storescene error: ' .. err end
   return res, err
function getSupportedColorTypeFeatures(gateway, addr)
   -- Get supported color type features
   -- Return pattern:
   -- If successful:
   -- xy - 0/1, unsupported/supported
   -- tc - 0/1, unsupported/supported
   -- direct - 0-5, how much channels support direct control
   -- rgbwaf - 0-5, how much rgbwaf channels
   -- else: nil, Command name with error
   res, err = dalicmd(gateway, 'querycolorfeatures', { addrtype = 'short', address = addr })
   if err then return nil, 'querycolorfeatures error: ' .. err end
   res = res:byte()
   xy = bit.band(res, 0x01)
   tc = bit.rshift(bit.band(res, 0x02), 1)
   direct = bit.rshift(bit.band(res, 0x1c), 2)
   rgbwaf = bit.rshift(bit.band(res, 0xe0), 5)
   return xy, tc, direct, rgbwaf
function getSceneTc(gateway, addr, scene)
   res, err = dalicmd(gateway, 'queryscene', { addrtype = 'short', address = addr, value = scene })
   if err then return nil, 'queryscene error: ' .. err end
   arc_level = res:byte()
   code = 226 -- parameter code to get scene Tc
   hb = res:byte()
   lb = res:byte()
   return arc_level, tc
Function for RGBW/RGBWAF Type 8 dimmer
function setRGBWAF(gateway, addr, r, g, b, w, a, f)
   if r == nil then r = 0 end
    if g == nil then g = 0 end
    if b == nil then b = 0 end
    if w == nil then w = 0 end
    if a == nil then a = 0 end
    if f == nil then f = 0 end
   res, err = dalicmd(gateway, 'setdtr0', { addrtype = 'short', address = addr, value = math.min(r, 254) })
   res, err = dalicmd(gateway, 'setdtr1', { addrtype = 'short', address = addr, value = math.min(g, 254) })
   if err then return nil, 'setdtr1 error: ' .. err end
   res, err = dalicmd(gateway, 'setdtr2', { addrtype = 'short', address = addr, value = math.min(b, 254) })
   res, err = dalicmd(gateway, 'setrgbdimlevel', { addrtype = 'short', address = addr })
   if err then return nil, 'setrgbdimlevel error: ' .. err end
   res, err = dalicmd(gateway, 'setdtr0', { addrtype = 'short', address = addr, value = math.min(w, 254) })
   res, err = dalicmd(gateway, 'setdtr1', { addrtype = 'short', address = addr, value = math.min(a, 254) })
   res, err = dalicmd(gateway, 'setdtr2', { addrtype = 'short', address = addr, value = math.min(f, 254) })
   res, err = dalicmd(gateway, 'setwafdimlevel', { addrtype = 'short', address = addr })
   if err then return nil, 'setwafdimlevel error: ' .. err end
   res, err = dalicmd(gateway, 'activate', { addrtype = 'short', address = addr })
   return res, err
function saveSceneRGBWAF(gateway, addr, scene, arc_level, r, g, b, w, a, f)
    if arc_level == nil then arc_level = 254 end
    return res, err
Functions to get current RGBWAF:
function getChannel(gateway, addr, code)
 return res, err
function getRGBWAF(gateway, addr)
 -- codes for RGBWAF could be 233-237 or 227-232
 res_t = {}
 for i = 233, 237, 1 do
   res, err = getChannel(gateway, addr, i)
   if res then table.insert(res_t, res:byte()) end
 return res_t
(26.12.2018, 12:22)Snoolik Wrote: Function for RGBW/RGBWAF Type 8 dimmer
   return res, err
    return res, err
Hello and thanks for your efforts.
first in the setRGBWAF function what are (gateway, addr), and how to convert the 251.600 6 byte DALI RGBW data type to fit the function (r,g,b,w,a,f)
regards,
Best Regards,
Use this, change gateway number and short address as needed:
gateway = 'internal'
addr = 12
value = event.getvalue()
    return res, err
setRGBWAF(gateway, addr, value.red, value.green, value.blue, value.white)
(06.07.2021, 10:58)admin Wrote: Use this, change gateway number and short address as needed:
addr = 12
    return res, err
thank you, admin
Great
can I read the RGBW Status?
Best Regards,
See this example: https://forum.logicmachine.net/showthrea...2#pid12902
(06.07.2021, 11:35)admin Wrote: See this example: https://forum.logicmachine.net/showthrea...2#pid12902
thank you admin for your great help and effort.
I do it like this and its wok
if you have any comments Smile
RgbwSts = getRGBWAF(gateway, addr)
WriteValue = {}
WriteValue["red"] = RgbwSts[1]
WriteValue["white"] = RgbwSts[4]
WriteValue["blue"] = RgbwSts[3]
WriteValue["green"] = RgbwSts[2]
Also, I need the feedback for the on/off object and scale(0-100%)
regards,
Best Regards,
See this: https://forum.logicmachine.net/showthrea...8#pid19988
(07.07.2021, 14:39)admin Wrote: See this: https://forum.logicmachine.net/showthrea...8#pid19988
thank you, admin
What is the right way to control a group of DALI Lights/short addresses at the same time?
Best Regards,
See this: https://forum.logicmachine.net/showthread.php?tid=133
I also recommend looking into our CANx-DALI gateway. It provides most of the features you need via UI instead of scripts.
(08.07.2021, 10:57)admin Wrote: See this: https://forum.logicmachine.net/showthread.php?tid=133
Thank you, admin
I will, but for this project, we already bought the products and give a price for the customer, unfortunately we didn't test everything before Sad
Best Regards,
