HELP luasocket changed in build 31
Please help.  I have the LM5 running RC1 firmware.  Luasocket is upgraded to luasocket_2.0.2-31_imx6.ipk  it was working in the 29 build.  This particular LM5 is running resident scripts for a websocket client which is working.  I really don't want to break that.
The UDP server does not receive when I have the TCP client active.  I can comment out the TCP client then it works.  The event script can send to the resident script fine.  I have tried changing the timeout value for both TCP client and the UDP server.  Makes no difference.  I need to use copas because I have delay commands sent out to the TCP device.
Does anyone have an idea.
Resident script on 0 seconds
if not ready then
  copas = require("copas")
  socket = require("socket")
  server = socket.udp()
  server:setsockname("127.0.0.1",51034)
  function handler(uskt)
    uskt = copas.wrap(uskt)
    log("UDP connection handler")
    while true do
      local s, err
      log("receiving...")
      s, err = uskt:receive(1024)
      if not s then
        log("Receive error: ")
        log(err)
        return
      log("Received data, bytes:")
      log(s)
  copas.addserver(server, handler, 0)
  function parse(data)
    log(data)
  function sendtcp(command)
    skt:send(command)
    sleep(0.5)
  function init()
    log('in init')
    sendtcp('#COSMSGS=false\r')
    sendtcp('#MODEL?\r')
  ready=true
if not skt then
  --add receive thread
  copas.addthread(function()
      local reconnect = function()
        skt, err = socket.connect('192.168.0.175', 4999)
        skt:settimeout(1)
        if(not err) then
          init()
          log('[tcp-client] error connecting ')
          return
      if not skt or skt==nil or skt.state=='CLOSED' then
        reconnect()
      if(skt)then
        while true do
          local resp,err = skt:receive('*r')
          -- if theres no connection start a new connection
          if(skt.state=='CLOSED')then
            if not resp then
              log("[tcp-client] Receive error: ")
              copas.removethread(skt)
              skt = nil
              break
            if(resp~=nil) then
              local fd,prtd = pcall(parse,resp)
              if(fd==false)then
                log("Error with parsemsg")
    end)
copas.loop()
Event script
if event.type=='groupwrite' then
  local client = socket.udp()
  local evt = event.dst..','..tostring(grp.getvalue(event.dst))
  log(evt)
  if client then
    client:sendto(evt, '127.0.0.1', 51034)
    client:close()
elseif event.type =='groupread' then
  grp.response(event.dst,grp.getvalue(event.dst))
I'll check this more thoroughly but there are some issues with your script:
1. Do not use socket.connect() because it is blocking, use copas.connect()
2. There's no need to pass any length to UDP receive. Without any length it will return one datagram (or error on timeout) per call
3. Your reconnect procedure seems wrong, you don't have to call removethread and sockets do not have state field
4. sendtcp does not check if socket is connected/available
copas.connect is blocking also. is there a working example with copas?
Roger
From docs:
copas.connect(skt, address, port)
Connects and transforms a master socket to a client just like LuaSocket socket:connect(). The Copas version does not block and allows the multitasking of the other handlers and threads.
That's what I did  and removed the bad stuff.  Still blocks out.  tried with or without timeout and timeout of 0 and 1.
if not skt then
     skt = socket.tcp()
       err = copas.connect(skt,'192.168.0.175', 4999)
       skt:settimeout(1)
       log(skt)
       log(err)
      if(skt)then
        init()
        while true do
            if(resp~=nil) then
              if(fd==false)then
    end)
Working example:
if not ready then
  copas = require('copas')
  udpserver = socket.udp()
  udpserver:setsockname('127.0.0.1', 51034)
  function udphandler(udpsock)
    udpsock = copas.wrap(udpsock)
    log('udp connection handler')
    while true do
      local data, err = udpsock:receive()
      if data then
        log('received data', data)
    log(data)
    if connected then
      tcpsock:send(command)
      copas.sleep(0.5)
  ready = true
  function tcpconnect()
    local sock = socket.tcp()
    tcpsock = copas.wrap(sock)
    tcpsock:settimeout(1)
    connected, err = tcpsock:connect('192.168.0.175', 4999)
    if connected then
      log('connect ok')
      log('connect failed', err)
      copas.sleep(1)
  function tcphandler()
    while true do
      if connected then
        local resp, err = tcpsock:receive('*r')
        if resp then
          local status, data = pcall(parse, resp)
          if not status then
            log('parse failed', data)
        elseif err == 'closed' then
          log('disconnected')
          connected = false
          tcpsock:close()
          tcpsock = nil
          collectgarbage('step')
          copas.sleep(1)
      if not connected then
        tcpconnect()
  copas.addserver(udpserver, udphandler, 0)
  copas.addthread(tcphandler)
copas.loop()
Yes it works, BIG thank you. Perfect. Have a great day.
Thanks,
Roger
