SNMP protocol in Logic Machine
Good guys, I told them that I have a problem with the request of the OID information of the UPS and that the code works for me, but after several hours, the code stops working and I have to disable and enable the resident function again so that the data can be updated, but after several hours again I can not obtain the values. I look at the error log and the following appears:
Resident script: 16: netsnmp: Unknown host (192.168.0.114) stack traceback: [C]: in function 'assert'
Resident script: 16: netsnmp: Unknown host (192.168.0.111) stack traceback:
The code is the following:
--Abrir una sesión con snmp require "snmp" local mib, err = snmp.mib.load('/home/ftp/snmp/Mikrotik.mib') if not mib then   log('Failed to load mib: ' .. err) end ups1, err = snmp.open{  version = snmp.SNMPv1,  community = "tekneoCO",  port = 161,  peer = "192.168.0.111", } assert(ups1, err) --Lee los OID del Mib vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.2.1.1.0") grp.write('8/0/0', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.2.2.5.0") grp.write('8/0/1', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.4.1.1.0") grp.write('8/0/2', vbind.value) vbind, err = ups1:get("1.3.6.1.2.1.33.1.2.5.0") grp.write('8/0/50', vbind.value) os.sleep(2) vbind, err = ups1:get("1.3.6.1.2.1.33.1.2.4.0") grp.write('8/0/7', vbind.value) vbind, err = ups1:get("1.3.6.1.2.1.33.1.2.3.0") grp.write('8/0/8', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.2.2.3.0") grp.write('8/0/51', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.3.2.4.0") grp.write('8/0/52', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.3.2.1.0") grp.write('8/0/53', vbind.value) os.sleep(2) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.4.2.2.0") grp.write('8/0/54', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.4.2.1.0") grp.write('8/0/55', vbind.value) vbind, err = ups1:get("1.3.6.1.2.1.33.1.4.4.1.5.1") grp.write('8/0/19', vbind.value) vbind, err = ups1:get("1.3.6.1.2.1.33.1.5.1.0") grp.write('8/0/56', vbind.value) vbind, err = ups1:get("1.3.6.1.2.1.33.1.5.3.1.2.1") grp.write('8/0/23', vbind.value) os.sleep(2) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.8.5.1.0") grp.write('8/0/26', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.8.5.7.0") grp.write('8/0/27', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.8.6.2.0") grp.write('8/0/28', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.8.6.3.0") grp.write('8/0/29', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.8.6.4.0") grp.write('8/0/30', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.8.7.5.0") grp.write('8/0/31', vbind.value) os.sleep(2) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.8.7.1.0") grp.write('8/0/32', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.8.7.4.0") grp.write('8/0/33', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.8.7.5.0") grp.write('8/0/34', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.8.7.6.0") grp.write('8/0/35', vbind.value) vbind, err = ups1:get("1.3.6.1.4.1.935.1.1.1.8.7.7.0") grp.write('8/0/36', vbind.value)
I must clarify that I have the UPS are connected to the network, the connection has not fallen and I have installed the two necessary SNMP packages and I do not have any MIB file (either Mikrotik or UPS) loaded, since the UPS that I am using does not they have a single MIB file, since one information is given to me by a MIB that I found and another one is given to me by another MIB and I did not use the code that the admin indicated after, because the current one seemed more comfortable to edit, besides that I had it done. Currently I ask the variables to 4 UPS, the first question is by resident code at 20 seconds, the second at 30 seconds, 40 and 50 seconds respectively. Thank you and I will be attentive to your comments.
RE: SNMP protocol in Logic Machine - by AEK - 04.09.2018, 09:17
RE: SNMP protocol in Logic Machine - by AEK - 06.09.2018, 06:59
RE: SNMP protocol in Logic Machine - by admin - 06.09.2018, 07:57
RE: SNMP protocol in Logic Machine - by admin - 07.09.2018, 07:00
RE: SNMP protocol in Logic Machine - by admin - 11.09.2018, 06:41
RE: SNMP protocol in Logic Machine - by AEK - 11.09.2018, 09:26
RE: SNMP protocol in Logic Machine - by admin - 12.09.2018, 05:58
RE: SNMP protocol in Logic Machine - by Carlos Padilla - 15.10.2018, 18:02
RE: SNMP protocol in Logic Machine - by admin - 15.10.2018, 18:10
RE: SNMP protocol in Logic Machine - by admin - 16.10.2018, 10:30
RE: SNMP protocol in Logic Machine - by admin - 16.10.2018, 17:50
RE: SNMP protocol in Logic Machine - by admin - 11.04.2019, 09:52
RE: SNMP protocol in Logic Machine - by admin - 17.06.2019, 07:34
RE: SNMP protocol in Logic Machine - by admin - 17.06.2019, 08:34
RE: SNMP protocol in Logic Machine - by admin - 18.06.2019, 08:05
RE: SNMP protocol in Logic Machine - by admin - 11.07.2019, 08:48
RE: SNMP protocol in Logic Machine - by admin - 12.07.2019, 06:15
RE: SNMP protocol in Logic Machine - by admin - 04.11.2019, 12:12
RE: SNMP protocol in Logic Machine - by admin - 21.02.2020, 08:22
RE: SNMP protocol in Logic Machine - by admin - 06.03.2020, 12:26
RE: SNMP protocol in Logic Machine - by admin - 06.03.2020, 18:47
RE: SNMP protocol in Logic Machine - by admin - 07.03.2020, 13:20
RE: SNMP protocol in Logic Machine - by admin - 09.03.2020, 09:21
RE: SNMP protocol in Logic Machine - by admin - 28.03.2020, 15:06
RE: SNMP protocol in Logic Machine - by admin - 12.04.2020, 12:12
RE: SNMP protocol in Logic Machine - by admin - 15.04.2020, 06:08
RE: SNMP protocol in Logic Machine - by admin - 09.12.2020, 07:07
RE: SNMP protocol in Logic Machine - by admin - 11.03.2021, 13:15
RE: SNMP protocol in Logic Machine - by admin - 11.03.2021, 13:34
RE: SNMP protocol in Logic Machine - by admin - 11.03.2021, 14:22
RE: SNMP protocol in Logic Machine - by admin - 19.09.2022, 13:00
