Problem with LM3 V2
today my client gave me feedback about that he cannot control his heating system which is controlled via this device(only by knx objects, no visu, visu is on Busch ComfortTouch).
I've checked this and this device was working but indeed on TP it has no telegrams traffic and last telegram received by this device was from 3 days ago. During this time there was "KNX TP: OK" status and no error in Errors tab, no errors in System logs.
If it is about load of this device:
- 1 short eventbased script with tag (3 temperatures runs it every 1 minute),
- 6 binary inputs,
- 3 analog inputs,
- KNX TP load ~15%
Firmware version: 20180828
It is also very strange that today when I've logged to it it had CPU load like ~2. In Processes app I've found that when I was connected with it in one moment there was 80% from KNX backend (I understand that this is because I am connected with it but normally there is no client so it should be very small) and ~0% from other source. I've found also that there is unnecessary Mosaic deamon which also consume ~0% but I've switched of it. I've let only 1 webbrowser tab and now there is load is 0.3-0.8.
I will monitor it but maybe there is some error in new firmware.
with normal TP load ~15% and a few scripts. In Processes app I've found that when I was connected with it in one moment there was 80% from KNX backend (I understand that this is because I am connected with it but normally there is no client so it should be very small)
Done is better than perfect
Problem with LM3 V2 - by buuuudzik - 30.10.2018, 13:14
RE: Problem with LM3 V2 - by admin - 30.10.2018, 13:28
RE: Problem with LM3 V2 - by Daniel - 30.10.2018, 13:32
RE: Problem with LM3 V2 - by buuuudzik - 30.10.2018, 13:42
RE: Problem with LM3 V2 - by Daniel - 30.10.2018, 13:53
RE: Problem with LM3 V2 - by admin - 30.10.2018, 13:55
RE: Problem with LM3 V2 - by buuuudzik - 30.10.2018, 14:18
RE: Problem with LM3 V2 - by buuuudzik - 30.10.2018, 16:01
RE: Problem with LM3 V2 - by admin - 31.10.2018, 08:59
RE: Problem with LM3 V2 - by buuuudzik - 31.10.2018, 09:36
RE: Problem with LM3 V2 - by admin - 31.10.2018, 09:42
RE: Problem with LM3 V2 - by buuuudzik - 01.12.2018, 07:51
RE: Problem with LM3 V2 - by Daniel - 03.12.2018, 08:46
RE: Problem with LM3 V2 - by buuuudzik - 03.12.2018, 09:31
RE: Problem with LM3 V2 - by admin - 03.12.2018, 09:37
RE: Problem with LM3 V2 - by Daniel - 03.12.2018, 09:41
RE: Problem with LM3 V2 - by buuuudzik - 03.12.2018, 10:34
