Binary input - refreshing interval
I think that there should be possibility to set refresh interval of binary input in LM Reactor. For use especially for important heating devices or e.g. door statuses.
And also there should be the possibility to set updating to current real value of input because when input changes it will send telegram to the bus but what when:
- telegram will not arrive to the TP?
- other device change its value?
Maybe second point is not a problem but it is possible and when telegram will be changed on bus then there is no possiblity to check what is real state of input. Because also LM will send state of GA in its memory, not sends real input value, when it was changed from bus or it wasn't fit on the bus.
Done is better than perfect
Binary input - refreshing interval - by buuuudzik - 20.11.2018, 10:36
