03.03.2016, 10:25
If you have a pre-defined sequence with 1500 channels then you need to use a different approach, as storage requests will take too much time to provide a smooth transition. The best way would be to create a table of states for each channel for each time slot (10 seconds, for example). I can give some more advice if you can specify how the sequence should behave.
