router
Is the Wiser for KNX in the main line 1.0? If that is the case just set it to TPUART, if the Wiser for KNX is in one of the 2 lines then TPUART is also fine but then you MUST disable KNX IP features. Or you can also set the Wiser for KNX as IP coupler in line 1 or 2 and remove the KNX IP interface/router in that line.
In any case make sure to not have 2 active IP devices (or TP couplers as backbone and also IP devices) in the same lines to avoid telegram loops.
router - by balatis - 20.11.2018, 19:40
RE: router - by Erwin van der Zwart - 20.11.2018, 19:46
RE: router - by balatis - 20.11.2018, 19:54
RE: router - by Erwin van der Zwart - 20.11.2018, 20:43
RE: router - by balatis - 21.11.2018, 19:15
RE: router - by Tokatubs - 28.08.2019, 19:26
RE: router - by Daniel - 29.08.2019, 07:32
