Widgets on SpaceLynk
Why don’t you just create 1 widget with a value box for setting the GW 1 to xx and a value box with EVG nr. Under this you create a slider and a on/off button.
Then you can handle the rest in a single script..
GW = grp.getvalue('1/1/1') EVG = grp.getvalue('1/1/2') if event.dst == '1/1/3' then -- bit value   grp.write('2/' .. GW .. '/' .. EVG, event.getvalue()) elseif event.dst == '1/1/4' then -- byte value   grp.write('3/' .. GW .. '/' .. EVG, event.getvalue()) end
This way the user just selects the GW and EVG by selector and the 2 elements control the selected EVG
Widgets on SpaceLynk - by suporte.arqtech - 22.11.2018, 12:13
Widgets on SpaceLynk - by Kai-Roger - 22.11.2018, 12:55
RE: Widgets on SpaceLynk - by Daniel - 22.11.2018, 13:15
RE: Widgets on SpaceLynk - by suporte.arqtech - 22.11.2018, 20:00
RE: Widgets on SpaceLynk - by buuuudzik - 22.11.2018, 20:44
RE: Widgets on SpaceLynk - by Erwin van der Zwart - 22.11.2018, 21:03
RE: Widgets on SpaceLynk - by CHOUAIBOU - 22.11.2018, 23:03
RE: Widgets on SpaceLynk - by CHOUAIBOU - 23.11.2018, 13:58
RE: Widgets on SpaceLynk - by suporte.arqtech - 26.11.2018, 11:31
RE: Widgets on SpaceLynk - by DGrandes - 17.12.2018, 20:46
RE: Widgets on SpaceLynk - by DGrandes - 18.12.2018, 12:56
RE: Widgets on SpaceLynk - by DGrandes - 18.12.2018, 20:26
