(01.12.2018, 10:33)mjaanes Wrote: If I understand integration with ETS correctly, the only way to export GAs from ETS and import into LM (or at least) spaceLYnk is via the OPC/ESF export format from ETS. This is an archaic export format from the stone age (ETS3) and one consequence is that the data point types are not imported into spaceLYnk. In a project with 500+ GAs, it becomes a very tedious task to manually correct the data point types wherever needed for visualization/scripting purposes.
Any plans to rather use the more modern XML format type from ETS, thereby being more aligned with the current year of 2018 and making our lives easier?
Thanks in advance
You just export your .knxproj to your desktop, and put it in this link:
http://openrb.com/knxproj/
Remember to check "Include parent level names in object name"
Then import the new file as "Json".
