LM5 polling rate KNX
Then do it via script.
Tag all objects which you want to pool with tag 'Read' and make a schedule script which will run as often as you want.  just make sure it will not run faster then time of execution of the script.  1000 X Delay
myobjects = grp.tag('Read') for _, object in pairs(myobjects) do  -- send read request to object  grp.read(object.address)  os.sleep(1) --dealy in seconds end
You can add also to start up script to read on boot.
LM5 polling rate KNX - by gs@el-24.no - 18.12.2018, 09:15
RE: LM5 polling rate KNX - by Daniel - 18.12.2018, 10:53
RE: LM5 polling rate KNX - by gs@el-24.no - 18.12.2018, 11:05
RE: LM5 polling rate KNX - by Daniel - 18.12.2018, 11:06
RE: LM5 polling rate KNX - by gs@el-24.no - 18.12.2018, 11:08
RE: LM5 polling rate KNX - by Daniel - 18.12.2018, 11:24
RE: LM5 polling rate KNX - by gs@el-24.no - 18.12.2018, 11:27
RE: LM5 polling rate KNX - by Daniel - 18.12.2018, 11:30
RE: LM5 polling rate KNX - by admin - 18.12.2018, 11:36
RE: LM5 polling rate KNX - by gs@el-24.no - 18.12.2018, 12:53
RE: LM5 polling rate KNX - by admin - 18.12.2018, 13:01
