Remaining time or counter
#21
(24.12.2018, 17:00)AlexLV Wrote: I think above just copy of previous post...
Guys, can you please post here final script?? I tried to make changes mentioned but not work for me..
Hi AlexLV,
Please find bellow the working script. There was an error in the time string format.
Merry Christmas
B.R,
Chouaibou.
-- ** Staircase logic with external time object and retriggering on input object Version 3.2 ** -- -- ****************************** Created by Erwin van der Zwart **************************** -- -- ************************************** SET PARAMETERS ************************************ -- -- Set output address AddressOutput = '32/1/21'  -- 01. 1 bit (boolean) -- Set external time address (optional) AddressExternalTime = '32/1/22' -- 07. 2 byte unsigned integer -- Use time left indication  UseTimeLeft = true -- Set to false if no time left indication is used  -- Set feedback adress of time left indication (optional) AddressTimeLeft = '32/1/23' -- 255 byte string -- Set time delay (Used when external time is not available) SetDelay = 120 -- 2 minutes -- Seconds or Minutes SetSec = true -- Set to false for Minutes -- Set factor delay (Multiplies Delay) SetFac = 1 -- Logic can be turned of by value 0 Off_by_Value_Zero = false -- ************************************** END PARAMETERS ************************************ -- -- *************************** DON'T CHANGE ANYTHING UNDER THIS LINE ************************ -- Input_Value = event.getvalue() if Off_by_Value_Zero == false and (Input_Value == false or Input_Value == 0) then  return else  tpid = storage.get('PID:' .. _SCRIPTNAME)  if tpid == nil then      pid = os.getpid()      storage.set('PID:' .. _SCRIPTNAME, pid)  else    pid = os.getpid()      storage.set('PID:' .. _SCRIPTNAME, pid)    os.kill(tpid, signal.SIGKILL)  end  function Calculate_Time(StairCaseTime)    if StairCaseTime > (86400 -1) then      StairCaseTime = (86400 -1)    end    local hours = math.floor(StairCaseTime / 3600 % 24)    local minutes = math.floor(StairCaseTime / 60 % 60)    local seconds = math.floor(StairCaseTime % 60)    time = {      day = 0,      hour = hours,      minute = minutes,      second = seconds,    }    time =string.format('%02d:%02d:%02d',time.hour,time.minute,time.second)    return time  end  if Input_Value == true or Input_Value == 1 then    ValueExternalTime = grp.getvalue(AddressExternalTime) or SetDelay    if SetSec == true then      Multiply_Seconds = 1    else      Multiply_Seconds = 60    end    StairCaseTime = ValueExternalTime * Multiply_Seconds * SetFac    ValueOutput = grp.getvalue(AddressOutput)    if ValueOutput == false then      grp.write(AddressOutput, true)    end    if UseTimeLeft == true then      if StairCaseTime > 0 then        time = Calculate_Time(StairCaseTime)        grp.update(AddressTimeLeft, time)        repeat          StairCaseTime = StairCaseTime - 1          time = Calculate_Time(StairCaseTime)          grp.update(AddressTimeLeft, time)          os.sleep(1)        until StairCaseTime == 0      end        else      os.sleep(StairCaseTime)    end    grp.write(AddressOutput, false)  elseif Input_Value == false or Input_Value == 0 then    ValueOutput = grp.getvalue(AddressOutput)    if ValueOutput == true then      if UseTimeLeft == true then        time = Calculate_Time(0)        grp.update(AddressTimeLeft, time)      end      grp.write(AddressOutput, false)    end  end  storage.delete('PID:' .. _SCRIPTNAME) end
Remaining time or counter - by Tokatubs - 15.12.2018, 21:29
RE: Remaining time or counter - by Tokatubs - 16.12.2018, 00:51
RE: Remaining time or counter - by AlexLV - 16.12.2018, 16:09
RE: Remaining time or counter - by AlexLV - 16.12.2018, 20:59
RE: Remaining time or counter - by Tokatubs - 18.12.2018, 19:35
RE: Remaining time or counter - by AlexLV - 19.12.2018, 22:14
RE: Remaining time or counter - by Thomas - 20.12.2018, 10:13
RE: Remaining time or counter - by admin - 20.12.2018, 10:54
RE: Remaining time or counter - by Tokatubs - 20.12.2018, 22:27
RE: Remaining time or counter - by Daniel - 21.12.2018, 08:42
RE: Remaining time or counter - by Tokatubs - 21.12.2018, 09:28
RE: Remaining time or counter - by Daniel - 21.12.2018, 12:18
RE: Remaining time or counter - by Daniel - 21.12.2018, 13:11
RE: Remaining time or counter - by Tokatubs - 21.12.2018, 22:54
RE: Remaining time or counter - by AlexLV - 24.12.2018, 17:00
RE: Remaining time or counter - by CHOUAIBOU - 25.12.2018, 13:24
RE: Remaining time or counter - by AlexLV - 26.12.2018, 09:05
RE: Remaining time or counter - by AlexLV - 06.01.2019, 23:05
RE: Remaining time or counter - by admin - 29.01.2020, 11:28
RE: Remaining time or counter - by admin - 29.01.2020, 13:34
RE: Remaining time or counter - by AlexLV - 30.01.2020, 07:14
RE: Remaining time or counter - by AlexLV - 30.01.2020, 12:41
RE: Remaining time or counter - by admin - 09.08.2022, 08:20
RE: Remaining time or counter - by admin - 09.08.2022, 10:09
RE: Remaining time or counter - by Novodk - 26.05.2023, 19:46
RE: Remaining time or counter - by Novodk - 27.05.2023, 07:02
RE: Remaining time or counter - by admin - 27.05.2023, 06:59
RE: Remaining time or counter - by admin - 27.05.2023, 07:06
RE: Remaining time or counter - by Novodk - 27.05.2023, 07:18
RE: Remaining time or counter - by admin - 29.05.2023, 08:29
RE: Remaining time or counter - by Novodk - 29.05.2023, 08:52
RE: Remaining time or counter - by FatMax - 29.05.2023, 09:04
RE: Remaining time or counter - by Novodk - 01.06.2023, 16:26
RE: Remaining time or counter - by admin - 11.09.2024, 13:40
