11.02.2019, 09:30
(11.02.2019, 09:00)admin Wrote: You can use this Custom JavaScript to close the window when 1/1/1 value changes:
Code:$(function(){ if (typeof grp === 'object') { grp.listen('1/1/1', function(obj, state) { if (state == 'value') { window.location.href = '/closekiosk'; } }); } });
Keep in mind that this code might run in case disconnect happens so a better solution is to use Link element with External link mode and External link set to /closekiosk
Thank you very much, I get a 404 error, to see if I can see the problem, thank you very much for the help ...
