close window
You can use the same script, but you need an additional control object.
1. Create a virtual object (32/1/1 in this example)
2. Replace 1/1/1 with virtual object address in Custom JavaScript code
3. Create another object for control.
4. Attach an event script to control object:
if event.getvalue() then   grp.write('32/1/1', false)   grp.write('32/1/1', true) end
This way sending on to control object will force value toggle for the virtual object. And this will execute close window via extension sequence.
close window - by Daponte - 11.02.2019, 07:18
RE: close window - by admin - 11.02.2019, 07:44
RE: close window - by Daponte - 11.02.2019, 07:57
RE: close window - by admin - 11.02.2019, 08:06
RE: close window - by Daponte - 11.02.2019, 08:44
RE: close window - by admin - 11.02.2019, 09:00
RE: close window - by Daponte - 11.02.2019, 09:30
RE: close window - by admin - 11.02.2019, 09:41
RE: close window - by Daponte - 11.02.2019, 09:55
RE: close window - by admin - 11.02.2019, 10:32
RE: close window - by Daponte - 11.02.2019, 10:50
RE: close window - by admin - 11.02.2019, 10:58
RE: close window - by Daponte - 11.02.2019, 11:20
RE: close window - by admin - 11.02.2019, 11:33
RE: close window - by Daponte - 11.02.2019, 11:37
RE: close window - by Daniel - 11.02.2019, 12:08
RE: close window - by Daponte - 11.02.2019, 14:06
RE: close window - by Daniel - 11.02.2019, 14:13
RE: close window - by Joep - 16.11.2019, 15:41
