Modbus variables: import massive
#20
Here is modified slave script.  I doubled the arrays for registers and added a shift.  Fill accordingly all the arrays.  registers1 will start from 4096 and registers2 will start from 8192. Make sure you add corresponding regdt for each register.  Shift can be changes by shiftR1 or shiftR2 parameter.
   if not mb then      require('genohm-scada.eibdgm')      require('luamodbus')          -- list of coil mapping, starting from 0      coils = { }              -- registers table 1 shift starting from 1          shiftR1 = 4095              -- list of register mapping, starting from 4096      registers1 = { '3/1/26', '3/1/29' }        -- list of register data types, element count must match registers table      regdt1 = { dt.int16, dt.int16 }                    -- registers table 2 shift starting from 1             shiftR2 = 8191           -- list of register mapping, starting from 8192      registers2 = { '3/1/32', '3/1/35' }        -- list of register data types, element count must match registers table      regdt2 = { dt.int16, dt.int16 }                        -- knx group write callback      function knxgroupwrite(event)        local value            -- try to find matching coil        for id, addr in ipairs(coils) do          if event.dst == addr then            value = knxdatatype.decode(event.datahex, dt.bool)            mb:setcoils(id - 1, value)          end        end            -- try to find matching register1        for id, addr in ipairs(registers1) do          if event.dst == addr then            value = knxdatatype.decode(event.datahex, regdt1[ id ])            mb:setregisters(id + shiftR1, value)          end        end             -- try to find matching register2        for id, addr in ipairs(registers2) do          if event.dst == addr then            value = knxdatatype.decode(event.datahex, regdt2[ id ])            mb:setregisters(id + shiftR2, value)          end        end          end          -- coil write callback      function mbwritecoils(coil, value)        local addr = coils[ coil + 1 ]        if addr then          grp.write(addr, value, dt.bool)        end      end          -- register write callback      function mbwriteregisters(register, value)        local addr1 = registers1[ register -shiftR1 ]            local addr2 = registers2[ register -shiftR2 ]        if addr1 then          grp.write(addr1, value, regdt1[ register - shiftR1])               elseif addr2 then          grp.write(addr2, value, regdt2[ register - shiftR2])        end      end              -- knx group monitor, handles group writes      knxclient = eibdgm:new({ timeout = 0.1 })      knxclient:sethandler('groupwrite', knxgroupwrite)          -- modbus slave, listen on all interfaces and default port 502      mb = luamodbus.tcp()      mb:open('0.0.0.0', 502)          -- setting slave id is optional      -- mb:setslave(1)          mb:setreceivetimeout(0.1)      mb:setmapping(#coils, 0, shiftR2 + 1 + #registers2, 0)          -- init coils      for id, addr in ipairs(coils) do        value = grp.getvalue(addr)        mb:setcoils(id - 1, value)      end          -- init registers1      for id, addr in ipairs(registers1) do        value = grp.getvalue(addr)        mb:setregisters(id + shiftR1, value)      end        -- init registers2      for id, addr in ipairs(registers2) do        value = grp.getvalue(addr)        mb:setregisters(id + shiftR2, value)      end          -- set callbacks for coil and register write      mb:setwritecoilcb(mbwritecoils)      mb:setwriteregistercb(mbwriteregisters)    end        -- handle modbus and knx    mb:handleslave()    knxclient:step()
RE: Modbus variables: import massive - by Daniel - 04.04.2019, 07:44
