06.05.2019, 11:56
(06.05.2019, 10:36)ole Wrote:(06.05.2019, 09:23)admin Wrote: Have you tried swapping A/B? Do you have RS485 GND connected?
Yes, I have tried to to change the ports (A/B), but have not connected the GND. Should it be connected?
Tried to use the RS-485 echo test resident script found in the manual for the LM5p-dr.
I tried it from RS485-1 to 3, 1-2, 3-2 and 2-3 with no message in either the log or the error log - is there something special one need to do with the script, I just copied it directly from the manual into a resident script, only changing the name of the port?
Thanks in advance
No, it doesn't say anything in either the error log or the log and it is connected to the middle rs485 port which should be port rs485-1
But here it says RS485-2 and RS232, according to the datasheet it is not the same.
Here is says rs485-2 has the rs232, while on the system status one can think it's the port 3. Where is it possible to check if I got the correct firmware on the LM?
if you hav 3*rs485 ports, then probably you installed incorrect Firmware, that could be reason of problems.
![[Image: 23hsxt0.jpg]](http://i67.tinypic.com/23hsxt0.jpg)
![[Image: 2ynqpg9.jpg]](http://i64.tinypic.com/2ynqpg9.jpg)
