Problems to get DMX to work
(09.05.2019, 06:17)admin Wrote: I suspect that there's a physical problem somewhere. Try a different wire and also try connecting GND signal.
After a bit of testing I managed to get it to work. Tried with different cables and even checked the end of line resistor, but the thing that made it work was to change the nummber of DMX addresses in the script from 12 to 13, which I find odd since I only had connected a 12 channels dmx driver/controller. Does anyone have a good explanation on this ?
In regards to how fast it changes the led light when changing it from the LM there is still a noticeable delay, but it varies from time to time how long it takes, which is strange since the dmx script is the only thing running on the LM.
Problems to get DMX to work - by ole - 04.05.2019, 19:18
RE: Problems to get DMX to work - by AEK - 06.05.2019, 08:20
RE: Problems to get DMX to work - by admin - 06.05.2019, 09:23
RE: Problems to get DMX to work - by ole - 06.05.2019, 10:36
RE: Problems to get DMX to work - by AEK - 06.05.2019, 11:56
RE: Problems to get DMX to work - by admin - 06.05.2019, 13:32
RE: Problems to get DMX to work - by ole - 07.05.2019, 06:27
RE: Problems to get DMX to work - by admin - 07.05.2019, 06:46
RE: Problems to get DMX to work - by ole - 07.05.2019, 06:55
RE: Problems to get DMX to work - by admin - 07.05.2019, 07:02
RE: Problems to get DMX to work - by ole - 07.05.2019, 10:28
RE: Problems to get DMX to work - by admin - 07.05.2019, 11:10
RE: Problems to get DMX to work - by ole - 07.05.2019, 11:39
RE: Problems to get DMX to work - by admin - 07.05.2019, 11:49
RE: Problems to get DMX to work - by ole - 08.05.2019, 08:25
RE: Problems to get DMX to work - by admin - 08.05.2019, 08:40
RE: Problems to get DMX to work - by ole - 08.05.2019, 10:18
RE: Problems to get DMX to work - by admin - 09.05.2019, 06:17
RE: Problems to get DMX to work - by ole - 16.05.2019, 08:46
RE: Problems to get DMX to work - by Dario - 09.02.2020, 15:50
RE: Problems to get DMX to work - by Dario - 11.02.2020, 00:02
RE: Problems to get DMX to work - by Rajesh - 18.03.2020, 07:16
RE: Problems to get DMX to work - by admin - 18.03.2020, 09:35
RE: Problems to get DMX to work - by Rajesh - 06.05.2020, 14:43
RE: Problems to get DMX to work - by admin - 10.05.2020, 07:14
