Icons linked to scripts
There's a better solution for your task, you can enable "Show control" for that element and add additional class "mydimmer" and style it via CSS.
Here's a small example to start from:
.usermode .mydimmer .btn {  text-shadow: none;  color: transparent;  background-size: 60%;  background-repeat: no-repeat;  background-position: center center; } .usermode .mydimmer .dimmer-down {  background-image: url('/scada/resources/icons/plus-minus-off.png'); } .usermode .mydimmer .dimmer-up {  background-image: url('/scada/resources/icons/plus-minus-on.png'); }
Also, you can enable "No bus write" for visualization elements, this will not send a KNX telegram to KNX/TP, only internally and to KNX/IP if enabled.
Icons linked to scripts - by Tinysprings - 28.07.2015, 20:07
RE: Icons linked to scripts - by admin - 29.07.2015, 06:12
RE: Icons linked to scripts - by Tinysprings - 29.07.2015, 06:23
