SNMP protocol in Logic Machine
#37
Hi Admin, thanks for replying. With the help of the library manual I understand the script a bit more, in addition to the version 3 SNMP, and then I will try to try the version with what the manual says. The problem I have is to write to an OID, I have already tried many things but it still does not work, I have even commented, tried several parts of the code but it still does not work. I put it together to see if I'm wrong about something. Thank you and I am attentive to your comments
val=event.getvalue() --Abrir una sesión con snmp require "snmp" --value=1 ups1, err = snmp.open{   version = snmp.SNMPv1,   community = "public",   port = 161,   peer = "192.168.0.248", } assert(ups1, err) vbOut, err = ups1:set("1.3.6.1.4.1.1248.4.1.1.2.1.0", 0) --vlist = { --{oid = "1.3.6.1.4.1.1248.4.1.1.2.1.0", 0} --} --vbind = { --{oid = "1.3.6.1.4.1.1248.4.1.1.2.1.0", type = TYPE_INTEGER32, value = "0"} --} --vbOut, err = ups1:set(vbIn) --vbOut, err = ups1:set(vbind) log(vbind) log(err) log(index) --assert(vbOut, err) --if value==true then   --vbind, err = ups1:set("1.3.6.1.4.1.1248.4.1.1.2.1.0", 1)    --else --vbind, err = ups1:set("1.3.6.1.4.1.1248.4.1.1.2.1.0", 0)        --end ups1:close()
RE: SNMP protocol in Logic Machine - by AEK - 04.09.2018, 09:17
RE: SNMP protocol in Logic Machine - by AEK - 06.09.2018, 06:59
RE: SNMP protocol in Logic Machine - by admin - 06.09.2018, 07:57
RE: SNMP protocol in Logic Machine - by admin - 07.09.2018, 07:00
RE: SNMP protocol in Logic Machine - by admin - 11.09.2018, 06:41
RE: SNMP protocol in Logic Machine - by AEK - 11.09.2018, 09:26
RE: SNMP protocol in Logic Machine - by admin - 12.09.2018, 05:58
RE: SNMP protocol in Logic Machine - by admin - 15.10.2018, 18:10
RE: SNMP protocol in Logic Machine - by admin - 16.10.2018, 10:30
RE: SNMP protocol in Logic Machine - by admin - 16.10.2018, 17:50
RE: SNMP protocol in Logic Machine - by admin - 11.04.2019, 09:52
RE: SNMP protocol in Logic Machine - by admin - 17.06.2019, 07:34
RE: SNMP protocol in Logic Machine - by admin - 17.06.2019, 08:34
RE: SNMP protocol in Logic Machine - by admin - 18.06.2019, 08:05
RE: SNMP protocol in Logic Machine - by admin - 11.07.2019, 08:48
RE: SNMP protocol in Logic Machine - by Carlos Padilla - 11.07.2019, 22:13
RE: SNMP protocol in Logic Machine - by admin - 12.07.2019, 06:15
RE: SNMP protocol in Logic Machine - by admin - 04.11.2019, 12:12
RE: SNMP protocol in Logic Machine - by admin - 21.02.2020, 08:22
RE: SNMP protocol in Logic Machine - by admin - 06.03.2020, 12:26
RE: SNMP protocol in Logic Machine - by admin - 06.03.2020, 18:47
RE: SNMP protocol in Logic Machine - by admin - 07.03.2020, 13:20
RE: SNMP protocol in Logic Machine - by admin - 09.03.2020, 09:21
RE: SNMP protocol in Logic Machine - by admin - 28.03.2020, 15:06
RE: SNMP protocol in Logic Machine - by admin - 12.04.2020, 12:12
RE: SNMP protocol in Logic Machine - by admin - 15.04.2020, 06:08
RE: SNMP protocol in Logic Machine - by admin - 09.12.2020, 07:07
RE: SNMP protocol in Logic Machine - by admin - 11.03.2021, 13:15
RE: SNMP protocol in Logic Machine - by admin - 11.03.2021, 13:34
RE: SNMP protocol in Logic Machine - by admin - 11.03.2021, 14:22
RE: SNMP protocol in Logic Machine - by admin - 19.09.2022, 13:00
