Alert Manager
#47
(07.06.2017, 18:09)Erwin van der Zwart Wrote: Hi,
You can put the alert manager into a iframe (use as URL: /apps/data/alerts ) inside your normal visu and when you do that, the back button is automaticly hidden. When you check the persist checkbox on the iframe settings the app will be opened automaticly when there is a new alert.
Inside the menu of the alert manager app you can disable the pagejump on new alerts. Audio will always be started or you can mute it for always in the app menu.
I trie create a iframe with URL: /apps/data/alerts/
When I access internally everything works fine. But when I access by cloud I have the error:
Not Found (#404)
Page not found.
The above error occurred while the Web server was processing your request.
Please contact us if you think this is a server error. Thank you.
Best regards,
Alert Manager - by Erwin van der Zwart - 07.02.2017, 10:36
RE: Alert Manager - by buuuudzik - 07.02.2017, 11:58
RE: Alert Manager - by Erwin van der Zwart - 07.02.2017, 12:23
RE: Alert Manager - by buuuudzik - 07.02.2017, 13:59
RE: Alert Manager - by Igor68 - 09.02.2017, 15:18
RE: Alert Manager - by Erwin van der Zwart - 09.02.2017, 18:44
RE: Alert Manager - by Igor68 - 13.02.2017, 10:41
RE: Alert Manager - by Erwin van der Zwart - 13.02.2017, 13:00
RE: Alert Manager - by Igor68 - 14.02.2017, 15:42
RE: Alert Manager - by Erwin van der Zwart - 14.02.2017, 15:56
RE: Alert Manager - by Igor68 - 15.02.2017, 01:38
RE: Alert Manager - by Erwin van der Zwart - 16.02.2017, 09:10
RE: Alert Manager - by Igor68 - 16.02.2017, 15:51
RE: Alert Manager - by admin - 16.02.2017, 16:06
RE: Alert Manager - by admin - 17.02.2017, 10:28
RE: Alert Manager - by Trond Hoyem - 20.02.2017, 07:09
RE: Alert Manager - by Erwin van der Zwart - 20.02.2017, 08:07
RE: Alert Manager - by Mirco - 20.02.2017, 14:05
RE: Alert Manager - by Erwin van der Zwart - 20.02.2017, 16:12
RE: Alert Manager - by Igor68 - 20.02.2017, 14:17
RE: Alert Manager - by admin - 20.02.2017, 14:24
RE: Alert Manager - by Igor68 - 20.02.2017, 15:39
RE: Alert Manager - by cekca - 07.06.2017, 14:28
RE: Alert Manager - by Erwin van der Zwart - 07.06.2017, 16:45
RE: Alert Manager - by Thomas - 07.06.2017, 17:26
RE: Alert Manager - by Erwin van der Zwart - 07.06.2017, 18:09
RE: Alert Manager - by Thomas - 08.06.2017, 09:30
RE: Alert Manager - by Erwin van der Zwart - 08.06.2017, 12:05
RE: Alert Manager - by Erwin van der Zwart - 01.08.2017, 20:52
RE: Alert Manager - by morak - 02.08.2017, 16:47
RE: Alert Manager - by davidsilva - 16.07.2019, 18:06
RE: Alert Manager - by suporte.arqtech - 29.11.2017, 17:19
RE: Alert Manager - by Erwin van der Zwart - 29.11.2017, 19:08
RE: Alert Manager - by andrepneves@gmail.com - 12.12.2017, 16:15
RE: Alert Manager - by Erwin van der Zwart - 12.12.2017, 19:00
RE: Alert Manager - by ajgarcia.reyse - 04.09.2018, 07:28
RE: Alert Manager - by Erwin van der Zwart - 04.09.2018, 08:20
RE: Alert Manager - by domotiqa - 24.09.2018, 16:36
RE: Alert Manager - by Erwin van der Zwart - 24.09.2018, 19:27
RE: Alert Manager - by Daniel - 25.09.2018, 07:23
RE: Alert Manager - by domotiqa - 26.09.2018, 07:25
RE: Alert Manager - by Daniel - 26.09.2018, 07:29
RE: Alert Manager - by dennisslutter - 02.10.2018, 15:39
RE: Alert Manager - by Erwin van der Zwart - 02.10.2018, 16:11
RE: Alert Manager - by domotiqa - 17.07.2019, 07:19
RE: Alert Manager - by Daniel - 17.07.2019, 07:46
RE: Alert Manager - by domotiqa - 17.07.2019, 13:18
RE: Alert Manager - by domotiqa - 01.10.2019, 04:59
RE: Alert Manager - by Erwin van der Zwart - 01.10.2019, 10:02
RE: Alert Manager - by Daniel - 06.12.2019, 13:33
RE: Alert Manager - by alexgleyzer - 25.02.2020, 17:52
RE: Alert Manager - by Erwin van der Zwart - 25.02.2020, 18:07
RE: Alert Manager - by alexgleyzer - 27.02.2020, 16:37
RE: Alert Manager - by Trond Hoyem - 30.03.2020, 09:06
RE: Alert Manager - by Daniel - 25.02.2020, 18:54
RE: Alert Manager - by davidchispas - 14.04.2020, 17:43
RE: Alert Manager - by Erwin van der Zwart - 14.04.2020, 20:23
RE: Alert Manager - by JRP - 24.06.2020, 11:09
RE: Alert Manager - by Erwin van der Zwart - 24.06.2020, 13:52
RE: Alert Manager - by JRP - 27.06.2020, 15:23
RE: Alert Manager - by Erwin van der Zwart - 27.06.2020, 19:58
alert manager problem - by Frank68 - 23.09.2020, 13:15
RE: Alert Manager - by Erwin van der Zwart - 23.09.2020, 21:30
RE: Alert Manager - by davidchispas - 12.01.2021, 09:31
RE: Alert Manager - by Daniel - 12.01.2021, 09:47
RE: Alert Manager - by davidchispas - 12.01.2021, 11:30
RE: Alert Manager - by Daniel - 12.01.2021, 11:31
RE: Alert Manager - by davidchispas - 12.01.2021, 11:35
RE: Alert Manager - by davidchispas - 14.01.2021, 15:42
RE: Alert Manager - by Daniel - 14.01.2021, 15:50
RE: Alert Manager - by Frank68 - 18.01.2021, 09:09
RE: Alert Manager - by JRP - 20.04.2021, 09:10
RE: Alert Manager - by Daniel - 20.04.2021, 09:13
RE: Alert Manager - by Erwin van der Zwart - 20.04.2021, 10:50
RE: Alert Manager - by JRP - 20.04.2021, 10:55
RE: Alert Manager - by xxyzz - 02.06.2024, 16:41
RE: Alert Manager - by admin - 03.06.2024, 06:51
RE: Alert Manager - by Erwin van der Zwart - 03.06.2024, 11:05
RE: Alert Manager - by iJAF - 03.06.2024, 11:33
RE: Alert Manager - by Daniel - 03.06.2024, 11:34
RE: Alert Manager - by xxyzz - 05.08.2024, 04:47
