Safari iOS full-screen issue
(19.05.2016, 14:17)David Wrote: Hi,
I would like to comment you a problem I've found when I open the visualization on full-screen display. This problems occurs only when I use Safari in iOS and in full-screen mode. I've created a direct link and when I open it Safari shows a pop-up where you can read the following message: "URL visualization could not be opened. The error was: "unknown error".".
Do you know which can be the error?
Regards,
David
Hi, this can be if you have iFrame with URL, which does not exist
for example: if you add iFrame with web interface of Amati Streaming player and then shutdown Amati and try to open LM Visualization you will recive this error
Safari iOS full-screen issue - by David - 19.05.2016, 14:17
RE: Safari iOS full-screen issue - by AEK - 20.05.2016, 13:25
