20.05.2016, 14:33
(20.05.2016, 13:43)Sandstrand Wrote: Hi!
The load average numbers I get on one of my LM4s are a bit high at times, usually with peaks of CPU/IO 1.7 1.4 1.2
Usually it ranges from 0.8 to 1.2 with a memory usage of ~20%, will this affect the LM4s operation in a negative way?
What are the recommended loads and what values should I strive for?
thats normal load, you can get peaks when you have a lot of telegrams on knx tp bus. some of our partners have lm with CPU/IO near 7 and it works.
normal CPU/IO is under 2.0
