06.11.2019, 09:37
(This post was last modified: 06.11.2019, 09:48 by Erwin van der Zwart.)
(06.11.2019, 08:58)Kai-Roger Wrote: And altso a KNX clock with a built-in battery can be used. But these of course need a little adjusting of the time along the year. GPS is better.
Always a nice discussion, in my opinion you should connect a IoT device to a network that supports IoT features (: If you don't you will lose functionality..
If you use our time sender MTN677290 you can connect a DCF77 antenna and set in the parameters the daylight saving time period so you don't need to change along the year. But i agree that a USB GPS probably would be a cheaper solution.
@Admin: Does it work native or do we need a script to set the time from the USB GPS fetched data?
