Multitouch Problem
See this topic: https://forum.logicmachine.net/showthrea...62#pid3962
Or use this custom JS as a starting point, i created this for screen cleaning
$(function(){     // Set your listener address and value here   var grpaddress = '1/1/4';   var objvalue = true;     // Set your screenclean time here   var screencleantime = 30;     // Set your text here   var screenclean_message = 'Screen cleaning mode is now active';   var screenclean_remaining_prefix = 'remaining time';   var screenclean_remaining_suffix = 'seconds';     // Add screencleaner and listener to your visu   if (typeof grp != 'undefined') {     grp.listen(grpaddress, function(object, state) {       var value = object.value;       if(value == objvalue && state === 'value'){         // Set start time         var counter = screencleantime;                 // Function to count down the timer         function countdown() {           var el = document.getElementById('countertext');           var intervalId = setInterval(function() {             counter = counter - 1;             $('#screencleantime').text(screenclean_remaining_prefix + ' ' + counter + ' ' + screenclean_remaining_suffix);             if (counter === 5 || counter === 3 || counter === 1) {                 $('#screencleantime').css("color", "#ff0000");             } else {                 $('#screencleantime').css("color", "#ffffff");             }             if (counter === 0 || counter < 0) {                clearInterval(intervalId);                 // Remove overlay from visu                   $('#screenclean').remove();             }           }, 1000);         };         // Add dynamicly the overlay to visu         $('body').append('<div id="screenclean" style="position:absolute;width:100%;height:100%;opacity:0.3;z-index:100;background:#000;"><div id="screenmessage" style="text-align:center;position:absolute;left:calc(50% - 200px);top:calc(50% - 100px);color:#ffffff;opacity:1;z-index:0;"><div><h4 id="screencleanmessage" style="min-width:100px;"></h4></div><div><h4 id="screencleantime" style="min-width:100px;"></h4></div></div>');         $('#screencleanmessage').text(screenclean_message);         $('#screencleantime').text(screenclean_remaining_prefix + ' ' + counter + ' ' + screenclean_remaining_suffix);         // Start Countdown         countdown();               } else {            // Remove overlay from visu on any other value         $('#screenclean').remove();       }     }, true); // Set to true if you want to trigger again on same object value   } });
PS: I don’t think address 0/250/59 is possible (:
Multitouch Problem - by savaskorkmaz - 03.05.2018, 20:57
RE: Multitouch Problem - by tassiebean - 29.12.2019, 13:52
RE: Multitouch Problem - by Erwin van der Zwart - 29.12.2019, 14:19
RE: Multitouch Problem - by tassiebean - 30.12.2019, 04:30
