Time in scada 08:00
You don’t need 2 widgets, all actions on your current widget are related to from-to times for comfort, standby mode etcetera, all you need is a scheduler to do that.
So the current widget must only hold the frame to the scheduler and there you set the from-to times for each mode. Your current widget layout can be dropped.
With CSS you could even match the colors of the scheduler page to the same colors as used in the visu.
Time in scada 08:00 - by Auzzii - 28.12.2019, 15:00
RE: Time in scada 08:00 - by Tokatubs - 28.12.2019, 19:08
RE: Time in scada 08:00 - by Auzzii - 30.12.2019, 14:04
RE: Time in scada 08:00 - by Auzzii - 02.01.2020, 15:43
RE: Time in scada 08:00 - by Erwin van der Zwart - 02.01.2020, 16:54
