Direct input/Step +/-
(12.02.2020, 11:02)Daniel. Wrote: Hi
1. You can do it via custom css like this. Change will be visible only in Visu not editor
.item-control-single .control-spinner {   transform: scale(0.75);   transform-origin: 0 0; }
2. In object visualisation parameters there is step you can set.
Thank you for the CSS-tip. It worked!
But, when I look at the visualization parameters, I can only change the steps with an integer. What, Am I doing wrong? The object type is a 2-byte
floating point, so I don't think this is causing the problem.
Direct input/Step +/- - by Amelie - 12.02.2020, 09:51
RE: Direct input/Step +/- - by Daniel - 12.02.2020, 11:02
RE: Direct input/Step +/- - by Amelie - 12.02.2020, 12:25
RE: Direct input/Step +/- - by Daniel - 12.02.2020, 12:27
