SolarEdge inverter
(12.02.2020, 14:28)Daniel. Wrote: Just create new object. If you make 4byte bus data_type then LM object must have the same.
I did  a lot of modbus integration and scaling factor was never dynamic, this wouldn't make sense at all.
Initially I misunderstood, but I think I got it right this time. Unfortunately I still only get the value of the first register.
This is the profile as it is at the moment:
{ "manufacturer": "SolarEdge",   "description": "SE6000 inverter",   "mapping": [   { "name": "I_AC_VoltageAN", "bus_datatype": "uint16", "type": "register", "address": 40079, "value_multiplier": 0.1},   { "name": "I_AC_VoltageSF", "bus_datatype": "int16", "type": "register", "address": 40082},   { "name": "I_AC_Power", "bus_datatype": "int16", "type": "register", "address": 40083},   { "name": "I_AC_Power_SF", "bus_datatype": "int16", "type": "register", "address": 40084},   { "name": "I_AC_Energy_WH", "bus_datatype": "float32", "data_type": "uint32", "type": "register", "address": 40093},   { "name": "I_AC_Energy_WH_SF", "bus_datatype": "int16", "type": "register", "address": 40095}   ] }
The object's datatype is 4 byte floating point and I still only get the value of the first register.
As to the scaling factor: there always has to be a first time:  Wink I can see the scaling factor changing whenever the value of the data register reaches a certain value. The SF object switches between 32767 and 0...
SolarEdge inverter - by baggins - 11.02.2020, 13:51
RE: SolarEdge inverter - by Daniel - 11.02.2020, 13:59
RE: SolarEdge inverter - by baggins - 11.02.2020, 14:24
RE: SolarEdge inverter - by admin - 11.02.2020, 14:58
RE: SolarEdge inverter - by baggins - 11.02.2020, 15:38
RE: SolarEdge inverter - by Daniel - 11.02.2020, 15:47
RE: SolarEdge inverter - by baggins - 12.02.2020, 12:55
RE: SolarEdge inverter - by Daniel - 12.02.2020, 13:02
RE: SolarEdge inverter - by baggins - 12.02.2020, 13:53
RE: SolarEdge inverter - by Daniel - 12.02.2020, 13:58
RE: SolarEdge inverter - by baggins - 12.02.2020, 14:25
RE: SolarEdge inverter - by admin - 12.02.2020, 14:24
RE: SolarEdge inverter - by Daniel - 12.02.2020, 14:28
RE: SolarEdge inverter - by baggins - 12.02.2020, 15:00
RE: SolarEdge inverter - by Daniel - 12.02.2020, 16:22
RE: SolarEdge inverter - by baggins - 12.02.2020, 16:48
RE: SolarEdge inverter - by admin - 12.02.2020, 16:35
RE: SolarEdge inverter - by admin - 12.02.2020, 17:01
RE: SolarEdge inverter - by baggins - 12.02.2020, 17:59
RE: SolarEdge inverter - by baggins - 13.02.2020, 09:04
RE: SolarEdge inverter - by ivob - 04.06.2024, 07:15
RE: SolarEdge inverter - by Daniel - 13.02.2020, 09:08
RE: SolarEdge inverter - by baggins - 13.02.2020, 09:33
RE: SolarEdge inverter - by Daniel - 13.02.2020, 09:51
RE: SolarEdge inverter - by baggins - 13.02.2020, 10:04
RE: SolarEdge inverter - by baggins - 13.02.2020, 12:43
RE: SolarEdge inverter - by Joep - 20.04.2020, 14:49
RE: SolarEdge inverter - by baggins - 21.04.2020, 08:14
RE: SolarEdge inverter - by Joep - 21.04.2020, 15:14
RE: SolarEdge inverter - by Daniel - 13.02.2020, 12:46
RE: SolarEdge inverter - by Daniel - 04.06.2024, 07:25
