SonOff
I am experimenting with some sonoff relays (with tasmota knx firmware) but i'm stuck...
I have a Logic Machine with TP mode and KNX IP features enabled but telegrams from KNX aren't reaching the relay neither telegrams from relay reaching LM.
I have sniffered the trafic from the relay and it seems that it does send packets on multicast ip but LM doesn't get them.
Can someone suggest why isn't working?
Below is the packet send from the relay
Frame 30259: 59 bytes on wire (472 bits), 59 bytes captured (472 bits) on interface \Device\NPF_{67AFBC6E-58C1-4C7A-B6BA-12E3F1C9FEF4}, id 0     Interface id: 0 (\Device\NPF_{67AFBC6E-58C1-4C7A-B6BA-12E3F1C9FEF4})         Interface name: \Device\NPF_{67AFBC6E-58C1-4C7A-B6BA-12E3F1C9FEF4}         Interface description: Wi-Fi     Encapsulation type: Ethernet (1)     Arrival Time: Feb 19, 2020 01:14:24.548519000 Χειμερινή ώρα GTB     [Time shift for this packet: 0.000000000 seconds]     Epoch Time: 1582067664.548519000 seconds     [Time delta from previous captured frame: 0.011575000 seconds]     [Time delta from previous displayed frame: 23.017785000 seconds]     [Time since reference or first frame: 610.015366000 seconds]     Frame Number: 30259     Frame Length: 59 bytes (472 bits)     Capture Length: 59 bytes (472 bits)     [Frame is marked: False]     [Frame is ignored: False]     [Protocols in frame: eth:ethertype:ip:udp:kip:cemi]     [Coloring Rule Name: UDP]     [Coloring Rule String: udp] Ethernet II, Src: Espressi_e6:6c:b0 (60:01:94:e6:6c:b0), Dst: IPv4mcast_17:0c (01:00:5e:00:17:0c)     Destination: IPv4mcast_17:0c (01:00:5e:00:17:0c)         Address: IPv4mcast_17:0c (01:00:5e:00:17:0c)         .... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)         .... ...1 .... .... .... .... = IG bit: Group address (multicast/broadcast)     Source: Espressi_e6:6c:b0 (60:01:94:e6:6c:b0)         Address: Espressi_e6:6c:b0 (60:01:94:e6:6c:b0)         .... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)         .... ...0 .... .... .... .... = IG bit: Individual address (unicast)     Type: IPv4 (0x0800) Internet Protocol Version 4, Src: 192.168.2.56, Dst: 224.0.23.12     0100 .... = Version: 4     .... 0101 = Header Length: 20 bytes (5)     Differentiated Services Field: 0x00 (DSCP: CS0, ECN: Not-ECT)         0000 00.. = Differentiated Services Codepoint: Default (0)         .... ..00 = Explicit Congestion Notification: Not ECN-Capable Transport (0)     Total Length: 45     Identification: 0x2279 (8825)     Flags: 0x0000         0... .... .... .... = Reserved bit: Not set         .0.. .... .... .... = Don't fragment: Not set         ..0. .... .... .... = More fragments: Not set     ...0 0000 0000 0000 = Fragment offset: 0     Time to live: 1     Protocol: UDP (17)     Header checksum: 0xdd5a [validation disabled]     [Header checksum status: Unverified]     Source: 192.168.2.56     Destination: 224.0.23.12 User Datagram Protocol, Src Port: 3671, Dst Port: 3671     Source Port: 3671     Destination Port: 3671     Length: 25     Checksum: 0x93c4 [unverified]     [Checksum Status: Unverified]     [Stream index: 48]     [Timestamps]         [Time since first frame: 494.709090000 seconds]         [Time since previous frame: 494.299232000 seconds] KNX/IP Routing Indication     KNX/IP Header: Routing Indication         Header Length: 6 bytes         Protocol Version: 1.0         Service Identifier: Routing Indication (0x0530)             Service Family: Routing (0x05)             Service Type: Routing Indication (0x0530)         Total Length: 17 bytes cEMI L_Data.ind, P=Low, H=6, Src=1.1.40, Dst=2/1/2, GroupValueWrite $01     Message Code: L_Data.ind (0x29)     Additional Info (0 bytes)         Additional Information Length: 0     Ctrl1: Prio = Low         1... .... = Frame Type: Standard (1)         ..1. .... = Repeat On Error: No (1)         ...1 .... = Broadcast Type: Domain (1)         .... 11.. = Priority: Low (3)         .... ..0. = Ack Wanted: No (0)         .... ...0 = Confirmation Error: No (0)     Ctrl2: Hops = 6         1... .... = Address Type: Group (1)         .110 .... = Hop Count: 6         .... 0000 = Extended Frame Format: 0x0     Source: 0x1128 = 1.1.40     Destination: 0x1102 = 2/1/2     Length: 1     TPCI         0... .... = Packet Type: Data (0)         .0.. .... = Sequence Type: Unnumbered (0)     APCI: GroupValueWrite         .... ..00 10.. .... = Service: GroupValueWrite (0x2)     Data: 01         ..00 0001 = Data: 0x01
George
SonOff - by gtsamis - 03.06.2019, 10:56
RE: SonOff - by gtsamis - 18.02.2020, 23:40
RE: SonOff - by Erwin van der Zwart - 19.02.2020, 07:35
RE: SonOff - by gtsamis - 21.02.2020, 08:15
RE: SonOff - by admin - 19.02.2020, 08:08
