BLE profiles
You can use a scheduled script or create a profile. See raiing-temperature.lua for a similar device.
I'm not sure that this conversion is correct:
temperature = (rx:byte(2) + rx:byte(1)) / 10
The temperature value is probably two bytes, so you need to shift one byte with multiply by 256. Try both ways as byte order is not known.
temperature = (rx:byte(2) * 256 + rx:byte(1)) / 10 temperature = (rx:byte(2) + rx:byte(1) * 256) / 10
All write functions like ble.sockwritereq return two values:
1. number of bytes written, -1 = error
2. last error number (errno), applicable only when first value is -1, see this for errno number description: https://www.thegeekstuff.com/2010/10/linux-error-codes/
BLE profiles - by morak - 29.01.2018, 11:37
RE: BLE profiles - by 1114752670@qq.com - 13.03.2019, 07:53
RE: BLE profiles - by Daniel - 13.03.2019, 08:48
RE: BLE profiles - by gjniewenhuijse - 13.03.2019, 11:06
RE: BLE profiles - by admin - 13.03.2019, 11:19
RE: BLE profiles - by benanderson_475 - 13.01.2020, 21:17
RE: BLE profiles - by admin - 14.01.2020, 07:44
RE: BLE profiles - by benanderson_475 - 21.04.2020, 01:00
RE: BLE profiles - by admin - 21.04.2020, 06:23
RE: BLE profiles - by benanderson_475 - 22.04.2020, 00:38
RE: BLE profiles - by admin - 22.04.2020, 10:53
RE: BLE profiles - by benanderson_475 - 12.03.2022, 10:12
