LoRa Range
For sure this will not work. Even if it would be out of the panel our little antenna wouldn't work on this distance, it works for around 300m. For any longer distances you need bigger antenna outside of your panel.  SF12 or maybe SF11 will be needed.
Here is photo how to re-solder the antenna.
This has to be 433MHz antenna with 4dbi. Will send you on email some links.
Have a read some articles as many factors can influence the range
https://smartmakers.io/en/lorawan-range-...nal-range/
LoRa Range - by sjfp - 27.05.2020, 20:58
RE: LoRa Range - by Daniel - 28.05.2020, 08:38
RE: LoRa Range - by sjfp - 28.05.2020, 09:01
RE: LoRa Range - by andrepneves@gmail.com - 26.11.2020, 18:20
RE: LoRa Range - by admin - 26.11.2020, 18:31
RE: LoRa Range - by andrepneves@gmail.com - 26.11.2020, 18:50
RE: LoRa Range - by admin - 26.11.2020, 18:55
RE: LoRa Range - by andrepneves@gmail.com - 04.12.2020, 12:48
RE: LoRa Range - by admin - 15.12.2020, 07:51
