widget template
You can create a script to convert 4-bit to 1-bit. In visualization object select 4-bit as Main object and 1-bit as Status object. This way the icon will show the status.
Script to determine 4-bit action (stop/up/down). Change 1-bit addresses and values as needed.
value = tonumber(event.datahex, 16) up = bit.band(value, 8) == 8 stop = bit.band(value, 7) == 0 if stop then   grp.write('32/1/3', true) elseif up then   grp.write('32/1/4', true) else   grp.write('32/1/5', true) end
widget template - by Frank68 - 10.07.2020, 06:18
RE: widget template - by admin - 10.07.2020, 06:44
RE: widget template - by Frank68 - 10.07.2020, 08:14
RE: widget template - by admin - 10.07.2020, 08:35
RE: widget template - by Frank68 - 10.07.2020, 14:37
RE: widget template - by Daniel - 10.07.2020, 15:33
