23.07.2020, 10:08
(22.07.2020, 15:05)admin Wrote: I've already mentioned what to check first. If the CPU is running but Ethernet connection is not working this might be either a hardware fault on LM side or an issue with cable/switch/router. When this happens and device is till running try re-plugging Ethernet cable and see if there is LED activity on the Ethernet port.Finally, the problem is not the LM.
The problem is with the client's router.
Thank you very much for your support.
