LM and Mikrotik routers
#20
Hi DGrandes,
this works fine on RouterOS 6.43.4 and LM 20200720 (you can paste these commands directly in Mikrotik's Terminal)
Read value:
/tool fetch url="http://remote:yourPassword111@192.168.1.13/scada-remote" http-data="m=json&r=grp&fn=getvalue&alias=1/0/1" http-content-type="application/json" http-method=post;
You should see something like this in Terminal:
      status: finished   downloaded: 0KiBC-z pause]     duration: 1s
By default output = file and the file scada-remote is created (in Files section). You can see object's 1/0/1 value in this file.
Note! In latest LM version there is IP blocker enabled in case of 5 unsuccessful login attempts. It's related to FTP, SSH, Remote services. The quickest remedy is to reboot your LM5. If this happens, you will see something like this:
  status: failed failure: connection timeout
Write value:
/tool fetch url="http://remote:yourPassword111@192.168.1.13/scada-remote" http-data="m=json&r=grp&fn=write&alias=1/0/1&value=1" http-content-type="application/json" http-method=post;
LM and Mikrotik routers - by AlexLV - 13.06.2017, 19:41
RE: LM and Mikrotik routers - by AEK - 14.06.2017, 07:50
RE: LM and Mikrotik routers - by AlexLV - 16.09.2017, 19:49
RE: LM and Mikrotik routers - by edgars - 09.03.2018, 13:41
RE: LM and Mikrotik routers - by DGrandes - 09.11.2019, 11:23
RE: LM and Mikrotik routers - by edgars - 11.11.2019, 07:54
RE: LM and Mikrotik routers - by DGrandes - 11.11.2019, 11:29
RE: LM and Mikrotik routers - by edgars - 11.11.2019, 12:39
RE: LM and Mikrotik routers - by DGrandes - 11.11.2019, 14:58
RE: LM and Mikrotik routers - by DGrandes - 30.08.2020, 17:09
RE: LM and Mikrotik routers - by admin - 30.08.2020, 17:25
RE: LM and Mikrotik routers - by DGrandes - 30.08.2020, 17:35
RE: LM and Mikrotik routers - by admin - 30.08.2020, 17:39
RE: LM and Mikrotik routers - by DGrandes - 30.08.2020, 17:45
RE: LM and Mikrotik routers - by admin - 31.08.2020, 11:36
RE: LM and Mikrotik routers - by DGrandes - 31.08.2020, 14:18
RE: LM and Mikrotik routers - by edgars - 01.09.2020, 07:02
LM and Mikrotik routers - by DGrandes - 07.09.2020, 16:24
