Sound and control
Sound: our vision is that amplifier must be "transparent". It should able to reproduce the sound as close as possible to the original source. The signal is fully digital right to the amplifier front-end. This guarantees very low noise and distortion levels.
Sync: we have master-slave ability but it's not perfectly in sync. Accurate sync will be possible with new CPU model that is already available for new LM’s. Currently, several players must be configured so they can access same remote files from FTP, NAS etc. Then one master player tells slaves which track to play.
Remote commands: you can set volume in [0..100] range with “set_vol” command. Give us some time, we will provide full command reference. Basically, everything that can be done through the web interface, can be done via HTTP API.
We have plans to add streaming services.
Sound and control - by yoggi - 22.08.2016, 19:50
RE: Sound and control - by admin - 24.08.2016, 11:35
