17.10.2020, 19:26
(14.10.2020, 22:31)buuuudzik Wrote: Currently it is possible to show only specified schedulers and hide holidays:
http://4n.lv:7999/scada-vis/schedulers?id=1&nohol
http://4n.lv:7999/scada-vis/schedulers?id=1,2&nohol
To allow further customization I've added yesteday another param support:
http://4n.lv:7999/scada-vis/schedulers?simple
http://4n.lv:7999/scada-vis/schedulers?i...hol&simple
But to use it you must add below code section to your Custom Javascript:
Code:$(function () { // Simplify and limit scheduler form if (location.href.match(/\/schedulers(.+)simple/g)) { function setCustomSchedulerView() { const inSchedulers = document.body.classList.contains("schedulers"); if (inSchedulers) { const eventForm = document.getElementById("event-form"); if (!eventForm) return; const findOnForm = (selector) => eventForm.querySelector(selector); const hideEl = (el) => (el.style.display = "none"); const disableEl = (el) => (el.disabled = true); const doOnSelector = (selector, handler) => { const el = findOnForm(selector); if (el) handler(el); }; const doOnGlobalSelector = (selector, handler) => { const el = document.querySelector(selector); if (el) handler(el); }; const doOnSelectorBeforeLabel = (selector, handler) => { const el = findOnForm(selector); if ( el && el.previousElementSibling && el.previousElementSibling.tagName === "LABEL" ) handler(el.previousElementSibling); }; const doOnSelectorAndParent = (selector, parentSelector, handler) => { let el = findOnForm(selector); if (el) { handler(el); let parent = null; let limit = 10; while (!parent && limit > 0) { el = el.parentElement; if (el && el.matches(parentSelector)) parent = el; if (!el || parent) break; limit--; } if (parent) handler(parent); } }; const hideSelector = (selector) => doOnSelector(selector, hideEl); const hideGlobalSelector = (selector) => doOnGlobalSelector(selector, hideEl); const hideSelectorAndParent = (selector, parentSelector) => doOnSelectorAndParent(selector, parentSelector, hideEl); const hideSelectorBeforeLabel = (selector) => doOnSelectorBeforeLabel(selector, hideEl); const disableSelector = (selector) => doOnSelector(selector, disableEl); const disableGlobalSelector = (selector) => doOnGlobalSelector(selector, disableEl); const disableSelectorAndParent = (selector, parentSelector) => doOnSelectorAndParent(selector, parentSelector, disableEl); const schedulerFormElementsConfig = [ // style can be one from: "visible", "hidden", "disabled" { name: "active", style: "hidden", selector: "#event-active", parent: ".checkbox", }, { name: "name", style: "disabled", selector: "#event-name", }, { name: "type", style: "visible", selector: "#event-type", }, { name: "type-sunrise-sunset", style: "visible", selector: "#event-type-sunrise-sunset", }, { name: "daysofweek", style: "hidden", selector: "#event-daysofweek", }, { name: "dayweeknrs", style: "hidden", selector: "#event-dayweeknrs", }, { name: "daysofmonth", style: "hidden", selector: "#event-daysofmonth", }, { name: "months", style: "hidden", selector: "#event-months", }, { name: "holidays", style: "hidden", selector: "#event-holidays", }, { name: "year", style: "hidden", selector: "#event-year", parent: ".checkbox", }, { name: "value-bool", style: "disabled", selector: "#event-value-bool", }, { name: "value-color", style: "disabled", selector: "#event-value-color", }, { name: "value-spinner", style: "disabled", selector: "#event-value-spinner", }, { name: "value-slider", style: "disabled", selector: "#event-value-slider", }, { name: "value-enums", style: "disabled", selector: "#event-value-enums", }, { name: "value-text", style: "disabled", selector: "#event-value-text", }, { name: "value-lighting", style: "disabled", selector: "#event-value-lighting", }, ]; schedulerFormElementsConfig.forEach((config) => { switch (config.style) { case "hidden": if (!config.parent) { hideSelector(config.selector); hideSelectorBeforeLabel(config.selector); } else { hideSelectorAndParent(config.selector, config.parent); hideSelectorBeforeLabel(config.parent); } break; case "disabled": if (!config.parent) { disableSelector(config.selector); } else { disableSelectorAndParent(config.selector, config.parent); } break; case "visible": default: } }); const schedulerGlobalButtonsConfig = [ { name: "logout", style: "hidden", selector: ".btn-logout", }, { name: "home", style: "hidden", selector: ".btn-home", }, { name: "scheduler-edit", style: "hidden", selector: ".scheduler-edit", }, { name: "add", style: "hidden", selector: "#event-add", }, { name: "delete", style: "hidden", selector: ".actions .delete", }, ]; schedulerGlobalButtonsConfig.forEach((config) => { switch (config.style) { case "hidden": hideGlobalSelector(config.selector); break; case "disabled": disableGlobalSelector(config.selector); break; case "visible": default: } }); } } setCustomSchedulerView(); } });
Every element you can customize by setting "visible", "hidden" or "disabled".
I can't access the virtual LM , what's the username and password? , with admin user and admin password no access
