11.11.2020, 14:22
		11.11.2020:
ekey FSX App v.2020108 is released
The installation package is now available in the LogicMachine App store and
can be downloaded: - http://www.ekey.lv/logicmachine/ekey-app...201108.ipk
User manual: http://www.ekey.lv/logicmachine/ekey-app...manual.pdf
Changes from previous v.20200711:
- The user can now register up to 3 RFID cards.
- Fields for RFID cards in the User records are hidden if there are no active scanners with an RFID option
- Enrollment function is extended with an interactive modal window and the feedback with a positive or negative enrollment result.
+ the fingerprint enroll, delete functions are temporally blocked until the concurent enrollment process is finished (because of credentials synchronization limitations between scanners)
- New function to delete the selected log records.
- New function to Save (or export) the selected log records information into csv (* or xls) file
+ to save the records to the xls file there is available external procedure to install / remove the luaxlswriter and its related packages (not available for LM2,LM3, LM4)
- New external function to update the scanner firmware to v. 06180115
