12.11.2020, 14:52
(10.11.2020, 08:44)Daniel. Wrote: Can you explain this once more please?
Thank you Daniel for your response. I would like to use Logic Machine app to connect to LM. In order to connect in remote I do not use your cloud but simply IPÂ address of site on the web. Hence the settings should be the following:
home: ip address of LM on the network.
remote: ip address of LM on web (static IP).
It is a simply port forwarding but I do not use the standard port (80 or 443) but other. Hence in order to connect I should use the following syntax:
static_ip_address:40443 (https port if I use android app)
static_ip_address:40080 (http port if I use IOS app)
Can I do that? Because in this way it does not work.
The only way is use in home configuration the static_IP_address (http port) but what happen if I am at home the internet is down?
I hope to be cleared.
