LM as Modbus Slave. datatype and offset
if not mb then   require('genohm-scada.eibdgm')   require('luamodbus')   -- list of coil mapping, starting from 0   coils = { '1/1/1', '1/1/2','1/1/3' ,'1/1/4' }   -- list of register mapping, starting from 0   registers = { '3/1/1', '3/1/2'}   -- list of register data types, element count must match registers table   regdt = { dt.uint16,dt.uint16}   -- knx group write callback   function knxgroupwrite(event)     local value     -- try to find matching coil     for id, addr in ipairs(coils) do       if event.dst == addr then         value = knxdatatype.decode(event.datahex, dt.bool)         mb:setcoils(id - 1, value)               end     end     -- try to find matching register     for id, addr in ipairs(registers) do       if event.dst == addr then         value = knxdatatype.decode(event.datahex, regdt[ id ])         mb:setregisters(id - 1, value)               end     end   end   -- coil write callback   function mbwritecoils(coil, value)     local addr = coils[ coil + 1 ]     if addr then       grp.write(addr, value, dt.bool)     end   end   -- register write callback   function mbwriteregisters(register, value)     local addr = registers[ register + 1 ]     if addr then       grp.write(addr, value, regdt[ register + 1])     end   end   -- knx group monitor, handles group writes   knxclient = eibdgm:new({ timeout = 0.1 })   knxclient:sethandler('groupwrite', knxgroupwrite)   -- modbus slave, listen on all interfaces and default port 502   mb = luamodbus.tcp()   mb:open('хх.хх.хх.хх', 502)   -- setting slave id is optional   --mb:setslave(1)   mb:setreceivetimeout(0.1)   mb:setmapping(#coils, 0, #registers, 0)   -- init coils   for id, addr in ipairs(coils) do     value = grp.getvalue(addr)     mb:setcoils(id - 1, value)   end   -- init registers   for id, addr in ipairs(registers) do     value = grp.getvalue(addr)     mb:setregisters(id - 1, value)   end   -- set callbacks for coil and register write   mb:setwritecoilcb(mbwritecoils)   mb:setwriteregistercb(mbwriteregisters) end -- handle modbus and knx mb:handleslave() knxclient:step()
changed nothing Sad
RE: LM as Modbus Slave. datatype and offset - by ikhy - 27.11.2020, 10:04
