17.12.2020, 11:58
(17.12.2020, 11:44)Daniel. Wrote: Status - System logs drop what you have there.Dec 17 11:56:13 Wiser for KNX daemon.notice openvpn[1056]: SIGUSR1[soft,init_instance] received, process restarting
Dec 17 11:56:13 Wiser for KNX daemon.warn openvpn[1056]: Could not determine IPv4/IPv6 protocol
Dec 17 11:56:13 Wiser for KNX daemon.err openvpn[1056]: RESOLVE: Cannot resolve host address: hlynk-vpn.wiserair.com:80 (Try again)
Dec 17 11:56:08 Wiser for KNX daemon.err openvpn[1056]: RESOLVE: Cannot resolve host address: hlynk-vpn.wiserair.com:80 (Try again)
Dec 17 11:56:03 Wiser for KNX daemon.info avahi-daemon[1040]: Service "Web Server on WiserforKNX" (/etc/avahi/services/http.service) successfully established.
Dec 17 11:56:03 Wiser for KNX daemon.info avahi-daemon[1040]: Server startup complete. Host name is WiserforKNX.local. Local service cookie is 1543352448.
Dec 17 11:56:02 Wiser for KNX daemon.notice openvpn[1054]: library versions: OpenSSL 1.1.1g 21 Apr 2020, LZO 2.10
Dec 17 11:56:02 Wiser for KNX daemon.notice openvpn[1054]: OpenVPN 2.4.9 arm-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [AEAD]
Dec 17 11:56:02 Wiser for KNX user.info sysinit: starting openvpn
Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Registering HINFO record with values 'ARMV5TEJL'/'LINUX'.
Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Registering new address record for 192.168.0.98 on eth0.IPv4.
Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Network interface enumeration completed.
Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: New relevant interface eth0.IPv4 for mDNS.
Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.98.
Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Loading service file /etc/avahi/services/http.service.
Dec 17 11:56:02 Wiser for KNX daemon.warn avahi-daemon[1040]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: avahi-daemon 0.7 starting up.
Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Successfully dropped root privileges.
Dec 17 11:56:02 Wiser for KNX daemon.info avahi-daemon[1040]: Found user 'nobody' (UID 65534) and group 'nogroup' (GID 65534).
Dec 17 11:55:56 Wiser for KNX user.info sysinit: /lib/genohm-scada/storage/db/current.db: OK
Dec 17 11:55:52 Wiser for KNX kern.notice kernel: [ 18.867299] random: nonblocking pool is initialized
Dec 17 11:55:40 Wiser for KNX kern.info kernel: [ 6.387062] fec 800f0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Dec 17 11:55:38 Wiser for KNX authpriv.info dropbear[800]: Running in background
Dec 17 11:55:38 Wiser for KNX authpriv.warn dropbear[795]: Failed loading /etc/dropbear/dropbear_ed25519_host_key
Dec 17 11:55:38 Wiser for KNX kern.info kernel: [ 4.715322] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc
Dec 17 11:55:38 Wiser for KNX user.info sysinit: /dev/mmcblk0p3: clean, 3409/228032 files, 84966/911104 blocks
Dec 17 11:55:38 Wiser for KNX user.info sysinit: e2fsck 1.45.6 (20-Mar-2020)
Dec 17 11:55:38 Wiser for KNX kern.info kernel: [ 4.386899] fec 800f0000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=800f0000.ethernet-1:00, irq=-1)
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 3.122301] fec 800f0000.ethernet eth0: Freescale FEC PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=800f0000.ethernet-1:00, irq=-1)
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 2.843504] watchdog timeout 60 seconds
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 1.752845] EXT4-fs (mmcblk0p2): re-mounted. Opts: nodelalloc
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.942147] Freeing unused kernel memory: 144K
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.941334] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.941028] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.775913] mmcblk0: p1 p2 p3
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.773252] mmcblk0: mmc0:59b4 USD 3.73 GiB
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.771039] mmc0: new high speed SDHC card at address 59b4
Dec 17 11:55:36 Wiser for KNX kern.warn kernel: [ 0.768914] mmc0: host does not support reading read-only switch, assuming write-enable
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.763236] Waiting for root device /dev/mmcblk0p2...
Dec 17 11:55:36 Wiser for KNX kern.err kernel: [ 0.762943] Warning: unable to open an initial console.
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.761000] rtc-ds1307 0-006f: setting system clock to 2020-12-17 11:55:34 UTC (1608206134)
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.754792] NET: Registered protocol family 17
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.754611] ip_tables: © 2000-2006 Netfilter Core Team
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.731263] mxs-mmc 80010000.ssp: initialized
Dec 17 11:55:36 Wiser for KNX kern.warn kernel: [ 0.699805] 80010000.ssp supply vmmc not found, using dummy regulator
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.698662] usbcore: registered new interface driver btusb
Dec 17 11:55:36 Wiser for KNX kern.info kernel: [ 0.693141] lirc_dev: IR Remote Control driver registered, major 248
Dec 17 11:55:35 Wiser for KNX kern.info kernel: [ 0.691725] i2c /dev entries driver
Dec 17 11:55:35 Wiser for KNX kern.info kernel: [ 0.690170] rtc-ds1307 0-006f: 64 bytes nvram
Dec 17 11:55:35 Wiser for KNX kern.info kernel: [ 0.690045] rtc-ds1307 0-006f: rtc core: registered mcp7941x as rtc0
