13.01.2021, 09:15
I reverse engineered it and used some excel to test the calculations and the one below works.
--- [Function] fbe_curve_2pt
--- Curve function with 2 points
--- [Comment]
--- Depending on a straight line defined by 2 points, this module supplies a y-value for an x-value.
--- The first point of the straight line is defined by x1 and y1.
--- The second point of the straight line is defined by x2 and y2.
--- If x is less than x1, then y=y1.
--- If x is greater than x2, then y=y2.
--- Only strictly monotone rising or falling functions can be realised. This means x1 < x2.
--- [Input]
--- Input [value, object, storage]
--- X1 [value, object, storage]
--- Y1 [value, object, storage]
--- X2 [value, object, storage]
--- Y2 [value, object, storage]
--- [Output]
--- out - Output [object, storage]
function fbe_curve_2pt(input, x1, y1, x2, y2)
if input <= x1 then
return y1
elseif input >= x2 then
return y2
local n1, n2 = y2 - y1, x1 - x2
if n1 < 0 then
n1 = n1 * -1
n2 = n2 * -1
local c = n1 / n2
return y2 + (x2 - input) * c
--- [Function] fbe_curve_2pt_offset
--- Curve function with 2 points and offset
--- [Comment]
--- Depending on straight lines defined by 2 points, this module supplies an x-value for a y-value.
--- The x and the y-axis can be shifted by the respective offset.
--- If x is less than (x1 offset x), then y=y1.
--- If x is greater than (x2 offset x), then y=y2.
--- [Input]
--- Input [object, storage]
--- Offset X [value, object, storage]
--- Offset Y [value, object, storage]
--- [Output]
function fbe_curve_2pt_offset(input, x1, y1, x2, y2, offsetX, offsetY)
if input <= (x1 + offsetX) then
return (y1 + offsetY)
elseif input >= (x2 + offsetX) then
return (y2+ offsetY)
if n1 < 0 then
n1 = n1 * -1
n2 = n2 * -1
local c = n1 / n2
return (y2 + offsetY) + ((x2 + offsetX) - input) * c
--- [Comment]
--- [Input]
--- [Output]
if input <= x1 then
return y1
return y2
if n1 < 0 then
n1 = n1 * -1
n2 = n2 * -1
local c = n1 / n2
--- [Comment]
--- [Input]
--- [Output]
if n1 < 0 then
n1 = n1 * -1
n2 = n2 * -1
local c = n1 / n2
