Paradox EVO192 integration
(01.12.2020, 21:05)mishoboss Wrote: Hi, thank you for this script! I'm investigating the best possible way to integrate a security system with KNX in my next project. Satel has INT-KNX-2, which is great, but it has certain limitations (e.g. only 64 addresses). There are some pricey 3rd party modules for DSC. And there is Paradox with PRT3 and pricey 3rd party modules again, or using Logic Machine alternatively. The last option I like the most, because I'll probably put a Logic Machine into the project anyways.
Two questions:
1. Does this script work with the newer Paradox serial module? PRT3 is now discontinued and replaced.
2. Are zone changes reported imidiately? For example if a motion sensor detects motion, is this reported on the same second?
Hi!
I definitelly should choose LM to integrate security system. You have no limits when using LM. Can program whatever you want.
Answers:
1. I havent tested it but if all commands are the same then it will work.
2. Yes, this is realtime info. In one project I am using movement from security as triger and switch lights when brightness is below setpoint.
Paradox EVO192 integration - by edgars - 13.11.2019, 09:00
RE: Paradox EVO192 integration - by gtsamis - 25.03.2022, 02:02
RE: Paradox EVO192 integration - by mishoboss - 01.12.2020, 21:05
RE: Paradox EVO192 integration - by fleeceable - 13.01.2021, 13:07
RE: Paradox EVO192 integration - by mishoboss - 26.06.2021, 05:27
RE: Paradox EVO192 integration - by Angeles - 27.10.2021, 11:41
RE: Paradox EVO192 integration - by admin - 22.02.2022, 12:09
RE: Paradox EVO192 integration - by admin - 22.02.2022, 15:16
RE: Paradox EVO192 integration - by JMemphix - 10.10.2022, 00:10
RE: Paradox EVO192 integration - by mishoboss - 22.04.2024, 08:47
RE: Paradox EVO192 integration - by Daniel - 22.04.2024, 08:54
