May it helps: I currently have 6 Modbus connections running (TCP/IP by CAT 7 the network switches accordenly). I Could solve the same problem by the pollinterval since only two device connections are necessary every 5 seconds. First one fails and after about 5 hours it will by even not more possible to loog into the LM. Some pollintervals i set to 300 seconds some to 10 .... Everything has been wonderful since then. It always faild by the conections with 6 and more linked objects per divice. So may is also a god idear to think about whitch parameters are really needed to set into a object often. Even to add an Device twice is possibel so a few datas can by checked and setet into an object every 5 secondes and the other datas on the same device can by checked just ever 500 seconds since they are just informations how anyway will not change that often....
Mondbus and Inverter
| Messages In This Thread |
Mondbus and Inverter - by Frank68 - 15.01.2021, 10:34
RE: Mondbus and Inverter - by Daniel - 15.01.2021, 10:52
RE: Mondbus and Inverter - by Frank68 - 15.01.2021, 12:34
RE: Mondbus and Inverter - by Daniel - 15.01.2021, 12:50
RE: Mondbus and Inverter - by Frank68 - 15.01.2021, 13:13
RE: Mondbus and Inverter - by Daniel - 15.01.2021, 13:30
RE: Mondbus and Inverter - by Frank68 - 15.01.2021, 13:52
RE: Mondbus and Inverter - by Daniel - 15.01.2021, 13:57
RE: Mondbus and Inverter - by Frank68 - 15.01.2021, 14:01
RE: Mondbus and Inverter - by Daniel - 15.01.2021, 14:06
RE: Mondbus and Inverter - by Frank68 - 15.01.2021, 15:39
RE: Mondbus and Inverter - by Hugo - 17.01.2021, 19:19
