LM5 REACTOR ZEROTIER PORTS
(05.02.2021, 07:53)admin Wrote: LM cannot dynamically switch the gateway without some additional scripts which is rather complicated. Network stuff like a backup channel should be configured on the router level, not on LM. At this moment there's no option to disable default route override for the mobile connection. If you disable the connection completely then you won't be able to send SMS.
OK in some cases I only have the LAN connection, what are the ports used by Zerotier, so that I can open them in the firewall?
LM5 REACTOR ZEROTIER PORTS - by Frank68 - 05.02.2021, 07:07
RE: LM5 REACTOR ZEROTIER PORTS - by admin - 05.02.2021, 07:38
RE: LM5 REACTOR ZEROTIER PORTS - by Frank68 - 05.02.2021, 07:41
RE: LM5 REACTOR ZEROTIER PORTS - by admin - 05.02.2021, 07:53
RE: LM5 REACTOR ZEROTIER PORTS - by Frank68 - 05.02.2021, 10:00
RE: LM5 REACTOR ZEROTIER PORTS - by Daniel - 05.02.2021, 10:02
