Google Chart API
Hello, I am trying to implement the use of surplus photovoltaic energy taking into account the weather and radiation forecast. Now I am trying to tune the algorithm, plotting with google charts some info. I am able to plot different values, but I am not able to solve two issues
- With several plots, tooltip is only visible in the first #plan. Exchanging from one #plan to the other, the one that wasn't working now works, and vice versa.
- there is differenci if I access to the plan from home page or directly from specific url, i.e. http://192.168.0.10/scada-vis/#21. now the information lixe axes title and legend
I attach a snapshot of plan21, whose has the first chart, the tooltip works properly but not the info like legend. I draw the cursor by hand Smile
[Image: kFCwn6T.jpg]
The #plan24 has not work the tooltip
[Image: wCNiCGP.jpg]
Changing the plot form #plan24 to #plan21 tooltips work well. And if I load 192.168.0.10/scada-vis/#21 the information like legend, it is showed
[Image: CzQLVaW.jpg]
The javascript used:
$(function(){   // load chart JS   $.getScript('https://www.gstatic.com/charts/loader.js', function() {         google.charts.load('current', {'packages':['gauge', 'corechart'],language: 'es'});       google.charts.setOnLoadCallback(drawSolcast);     google.charts.setOnLoadCallback(drawGraphBC);     //------------------------------------------------------------------------------------------------     //-- plan21, graph consumo BC     //---      function drawGraphBC() {        // create empty element and add it to plan with ID=21       var graphEl = $('<div></div>').css({         position: 'absolute',         width: 1000, height: 350,         top: 20,  left: 20       }).appendTo('#plan-21');       $.getJSON('/user/energia.lp', function(jsonData) {         console.log(jsonData);         var data4 = new google.visualization.arrayToDataTable(jsonData);              var opt4 = { title: 'Calefacción / ACS' ,           width: 1000, height: 350,           // Gives each series an axis that matches the vAxes number below.           focusTarget: 'category',            seriesType: 'bars',           series: {             0: {targetAxisIndex: 0, areaOpacity: 1, lineWidth: 1},             1: {targetAxisIndex: 0, areaOpacity: 1, lineWidth: 1},             2: {targetAxisIndex: 1, areaOpacity: 0, visibleInLegend: false, type: 'line'}           } ,           vAxes: {             // Adds titles to each axis.             0: {title: 'Potencia [kW]', viewWindow: {min: 0, max:2500} },             1: { title: 'COP', gridlines: { interval: [ 1, 2, 3, 4, 5, 6 ] },                 viewWindow: {min: 1, max: 6}, gridlines: { count: 0} }           }         };         var chart4 = new google.visualization.ComboChart(graphEl.get(0));         chart4.draw(data4, opt4);       }); //getJSON     }; //drawWCons        //------------------------------------------------------------------------------------------------     //-- plan24, grafica weather     //---     function drawSolcast() {        // create empty element and add it to plan with ID=24       var graphSol = $('<div></div>').css({         position: 'absolute',         width: 1000, height: 350,         top: 400, left: 20,         border: 'solid'       }).appendTo('#plan-21');             $.getJSON('/user/sol2graph.lp', function(jsonObj) {         console.log(jsonObj);         var data5 = new google.visualization.DataTable();         data5.addColumn('date', 'fecha');         data5.addColumn('number', "pv_estimate");         data5.addColumn('number', "kWh/dia");                   // a formato tiempo         for (var i = 0; i < jsonObj.length; i++) {           jsonObj[i][0] = new Date( jsonObj[i][0] * 1000);         }               data5.addRows(jsonObj);                 var tickMarks = [];         var hoy = new Date()         for (var i = 0; i < 7; i++) {           tickMarks.push(new Date(hoy.getTime() + i*24*60*60*1000));         }                               var opt5 = { title: 'Pv kWh' ,           width: 1000, height: 350,           chartArea: {width: '90%', height: '80%'},           focusTarget: 'category',            seriesType: 'lines',           hAxis: {             format: 'EE, d MMM',             gridlines: { count: 7},             ticks: tickMarks           },            series: {             0: {targetAxisIndex: 0, areaOpacity: 1, lineWidth: 1},             1: {targetAxisIndex: 1, areaOpacity: 0.2, lineWidth: 1, type: 'area', color: '#f1ca3a' }           },           vAxes: {             // Adds titles to each axis.             0: {title: '[kW]', viewWindow: {min: 0, max:3.5}, gridlines: {interval: [ 0.5, 1, 1.5, 2, 2.5, 3 ] }},             1: { viewWindow: {min: 0, max: 70}, gridlines: { count: 0}, ticks: [ ] }           }         };                 var date_formatter = new google.visualization.DateFormat({ pattern: 'dd MMM, HH:mm' });         date_formatter.format(data5, 0);                 var chart5 = new google.visualization.ComboChart(graphSol.get(0));                              chart5.draw(data5, opt5);       }); //getJSON     }; //drawSolcast             }); // getscript });
Any help is welcome, thanks
Jose
Google Chart API - by andrepneves@gmail.com - 17.05.2018, 11:47
RE: Google Chart API - by admin - 17.05.2018, 12:28
RE: Google Chart API - by admin - 21.05.2018, 12:29
RE: Google Chart API - by admin - 25.05.2018, 06:39
RE: Google Chart API - by domotiqa - 28.02.2020, 06:54
RE: Google Chart API - by toujour - 31.03.2020, 09:07
RE: Google Chart API - by Daniel - 31.03.2020, 09:35
RE: Google Chart API - by toujour - 31.03.2020, 13:00
RE: Google Chart API - by jose_dli - 22.02.2021, 19:50
RE: Google Chart API - by admin - 23.02.2021, 08:50
RE: Google Chart API - by jose_dli - 23.02.2021, 10:05
RE: Google Chart API - by admin - 23.02.2021, 10:20
RE: Google Chart API - by jose_dli - 23.02.2021, 11:29
RE: Google Chart API - by jose_dli - 24.02.2021, 18:21
RE: Google Chart API - by legolas2069 - 06.03.2023, 08:01
RE: Google Chart API - by admin - 06.03.2023, 12:20
