BAR CHANGE SIZE 0 to 100%
No Custom CSS is needed, just add Custom JavaScript and set Additional classes property to bar for all required visualization elements. Objects must have 1-byte scale (0..100%) data type to work properly.
Another option is to use clip-path property so icon is clipped from the top instead of from the bottom as in the previous example. Make sure that only one script is used at a time.
$(function(){   if (typeof grp == 'undefined') {     return;   }      $('.bar').each(function(_, wrapel) {     var wrap = $(wrapel);     var addr = wrap.data('object');     var el = wrap.find('.icon').css('transition', 'clip-path 1s linear');     grp.listen(addr, function(object) {       el.css('clip-path', 'inset(' + (100 - object.value) + '% 0 0 0)')     }, true);   }); });
BAR CHANGE SIZE 0 to 100% - by Acla - 19.02.2021, 18:12
RE: BAR CHANGE SIZE 0 to 100% - by admin - 22.02.2021, 08:26
RE: BAR CHANGE SIZE 0 to 100% - by Acla - 24.02.2021, 09:33
RE: BAR CHANGE SIZE 0 to 100% - by admin - 24.02.2021, 11:00
RE: BAR CHANGE SIZE 0 to 100% - by Acla - 25.02.2021, 09:27
RE: BAR CHANGE SIZE 0 to 100% - by admin - 25.02.2021, 10:21
RE: BAR CHANGE SIZE 0 to 100% - by Acla - 28.02.2021, 11:43
RE: BAR CHANGE SIZE 0 to 100% - by Acla - 28.02.2021, 18:41
RE: BAR CHANGE SIZE 0 to 100% - by admin - 01.03.2021, 08:24
RE: BAR CHANGE SIZE 0 to 100% - by Acla - 01.03.2021, 18:30
RE: BAR CHANGE SIZE 0 to 100% - by admin - 02.03.2021, 07:21
