Creating a KNx point for Modbus Device Communication Error Situation
Hi Savaskorkmaz,
I don't know if there is a function for this in the system, but i solved it once with a little resident script.
Put your actions on the position where the logging is now (replace them with your action).
-- Check all modbus meters for connection query = 'SELECT * FROM modbus_devices' meter_state = db:getall(query) previous_state = storage.get('meterstate') if previous_state == nil then  for _, device in ipairs(meter_state) do    if device.active == 0 then      log(device.name .. " = down")    else      log(device.name .. " = active")    end  end  storage.set('meterstate', meter_state) else  for _, device in ipairs(meter_state) do    if device.active ~= previous_state[_].active then      log(device.name .. ' is changed to ' .. device.active)    end      end  storage.set('meterstate', meter_state) end
Erwin van der Zwart
RE: Creating a KNx point for Modbus Device Communication Error Situation - by Erwin van der Zwart - 03.10.2016, 15:36
