Logic Machine and PT Temperature sensor
(07.04.2021, 08:15)admin Wrote: What you're describing sounds like an NTC (negative temperature coefficient) sensor. PT1000 sensors have 1Kohm at 0 degrees and the resistance get higher when the temperature gets higher.
Yes I asked and I ahve been told that this is a 10 Kohm sensor that when is heated the resistance is getting lower, so yes its an NTC sensor and I don't know if I can use it with MDTs input device then, or I must take an PT1000 along with the MDT input device
RE: Logic Machine and PT Temperature sensor - by vmic - 07.04.2021, 08:40
