Filter modbus register
(28.04.2021, 07:51)Daniel. Wrote: write_bitmask Boolean FW 2020.10 and newer
Set to true to enable writing shifted value to the register using value_bitmask. Only uint16 datatype is supported
Hello
the json file below makes me a strange thing, any bit I write in the LM always writes me only the first bit in the PLC.
the strange thing is that as far as the analog values are concerned, everything works perfectly.
Where am I wrong?
{   "manufacturer": "SIEMENS",   "description": "S7 1200",   "mapping": [     {"name": "SERRA 7 SP TEMP","address": 0,"bus_datatype": "float32","datatype": "float32","type": "register","units": " C°","writable": "true"},     {"name": "SERRA 7 TEMP","address": 2,"bus_datatype": "float32","datatype": "float32","type": "register","units": " C°","writable": "true"},     {"name": "SERRA 7 V_MAN_REG","address": 4,"bus_datatype": "float32","datatype": "float32","type": "register","units": " Hz","writable": "true"},     {"name": "SERRA 7 ISTERESI","address": 6,"bus_datatype": "float32","datatype": "float32","type": "register","units": " C°","writable": "true"},     {"name": "SERRA 7 ASS 1","address": 8,"bus_datatype": "float32","datatype": "float32","type": "register","units": " A","writable": "false"},     {"name": "SERRA 7 ASS 2","address": 10,"bus_datatype": "float32","datatype": "float32","type": "register","units": " A","writable": "false"},     {"name": "SERRA 7 A/M REG","address": 12,"read_swap":"bw","value_bitmask":"0x1","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 7 CMD INV 1","address": 12,"read_swap":"bw","value_bitmask":"0x2","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 7 RUN INV 1","address": 12,"read_swap":"bw","value_bitmask":"0x4","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},         {"name": "SERRA 7 ALM INV 1","address": 12,"read_swap":"bw","value_bitmask":"0x8","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},         {"name": "SERRA 7 ACK INV 1","address": 12,"read_swap":"bw","value_bitmask":"0x10","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 7 CMD INV 2","address": 12,"read_swap":"bw","value_bitmask":"0x20","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 7 RUN INV 2","address": 12,"read_swap":"bw","value_bitmask":"0x40","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},         {"name": "SERRA 7 ALM INV 2","address": 12,"read_swap":"bw","value_bitmask":"0x80","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},         {"name": "SERRA 7 ACK INV 2","address": 12,"read_swap":"bw","value_bitmask":"0x100","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 8 SP TEMP","address": 14,"bus_datatype": "float32","datatype": "float32","type": "register","units": " C°","writable": "true"},     {"name": "SERRA 8 TEMP","address": 16,"bus_datatype": "float32","datatype": "float32","type": "register","units": " C°","writable": "true"},     {"name": "SERRA 8 V_MAN_REG","address": 18,"bus_datatype": "float32","datatype": "float32","type": "register","units": " Hz","writable": "true"},     {"name": "SERRA 8 ISTERESI","address": 20,"bus_datatype": "float32","datatype": "float32","type": "register","units": " C°","writable": "true"},     {"name": "SERRA 8 ASS 1","address": 22,"bus_datatype": "float32","datatype": "float32","type": "register","units": " A","writable": "false"},     {"name": "SERRA 8 ASS 2","address": 24,"bus_datatype": "float32","datatype": "float32","type": "register","units": " A","writable": "false"},     {"name": "SERRA 8 A/M REG","address": 26,"read_swap":"bw","value_bitmask":"0x1","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 8 CMD INV 1","address": 26,"read_swap":"bw","value_bitmask":"0x2","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 8 RUN INV 1","address": 26,"read_swap":"bw","value_bitmask":"0x4","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},         {"name": "SERRA 8 ALM INV 1","address": 26,"read_swap":"bw","value_bitmask":"0x8","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},         {"name": "SERRA 8 ACK INV 1","address": 26,"read_swap":"bw","value_bitmask":"0x10","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 8 CMD INV 2","address": 26,"read_swap":"bw","value_bitmask":"0x20","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 8 RUN INV 2","address": 26,"read_swap":"bw","value_bitmask":"0x40","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},         {"name": "SERRA 8 ALM INV 2","address": 26,"read_swap":"bw","value_bitmask":"0x80","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},         {"name": "SERRA 8 ACK INV 2","address": 26,"read_swap":"bw","value_bitmask":"0x100","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 9 SP TEMP","address": 28,"bus_datatype": "float32","datatype": "float32","type": "register","units": " C°","writable": "true"},     {"name": "SERRA 9 TEMP","address": 30,"bus_datatype": "float32","datatype": "float32","type": "register","units": " C°","writable": "true"},     {"name": "SERRA 9 V_MAN_REG","address": 32,"bus_datatype": "float32","datatype": "float32","type": "register","units": " Hz","writable": "true"},     {"name": "SERRA 9 ISTERESI","address": 34,"bus_datatype": "float32","datatype": "float32","type": "register","units": " C°","writable": "true"},     {"name": "SERRA 9 ASS 1","address": 36,"bus_datatype": "float32","datatype": "float32","type": "register","units": " A","writable": "false"},     {"name": "SERRA 9 ASS 2","address": 38,"bus_datatype": "float32","datatype": "float32","type": "register","units": " A","writable": "false"},     {"name": "SERRA 9 A/M REG","address": 40,"read_swap":"bw","value_bitmask":"0x1","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 9 CMD INV 1","address": 40,"read_swap":"bw","value_bitmask":"0x2","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 9 RUN INV 1","address": 40,"read_swap":"bw","value_bitmask":"0x4","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},         {"name": "SERRA 9 ALM INV 1","address": 40,"read_swap":"bw","value_bitmask":"0x8","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},         {"name": "SERRA 9 ACK INV 1","address": 40,"read_swap":"bw","value_bitmask":"0x10","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 9 CMD INV 2","address": 40,"read_swap":"bw","value_bitmask":"0x20","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},     {"name": "SERRA 9 RUN INV 2","address": 40,"read_swap":"bw","value_bitmask":"0x40","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},         {"name": "SERRA 9 ALM INV 2","address": 40,"read_swap":"bw","value_bitmask":"0x80","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"},         {"name": "SERRA 9 ACK INV 2","address": 40,"read_swap":"bw","value_bitmask":"0x100","bus_datatype": "bool","datatype": "uint16","type": "register","writable": "true"} ] }
Thanks so much
Thanks so much
Filter modbus register - by Frank68 - 27.04.2021, 12:06
RE: Filter modbus register - by Daniel - 27.04.2021, 12:17
RE: Filter modbus register - by Frank68 - 27.04.2021, 12:26
RE: Filter modbus register - by Daniel - 27.04.2021, 12:29
RE: Filter modbus register - by Frank68 - 27.04.2021, 13:07
RE: Filter modbus register - by Daniel - 27.04.2021, 13:13
RE: Filter modbus register - by Frank68 - 27.04.2021, 14:03
RE: Filter modbus register - by admin - 27.04.2021, 14:11
RE: Filter modbus register - by Frank68 - 27.04.2021, 16:25
RE: Filter modbus register - by Daniel - 27.04.2021, 19:49
RE: Filter modbus register - by Frank68 - 28.04.2021, 06:15
RE: Filter modbus register - by Daniel - 28.04.2021, 07:51
RE: Filter modbus register - by Frank68 - 28.04.2021, 09:25
RE: Filter modbus register - by Daniel - 28.04.2021, 09:29
RE: Filter modbus register - by Frank68 - 28.04.2021, 10:01
